Is there any alternative to Teflon?
October 15, 2013 07:28PM
I've been at this for some time, following noophead, Q'bd, etc.
Basically, when you push filament through a hotend, it goes from solid, to tacky, to honey in consistency. During this transition, it goes from low friction to ultra-high friction to low friction again. As a result, pushing on a tacky, half-melted region of plastic causes the forces to go sideways instead of out, and you end up with a useless extruder.
By design, most extruders use polished stainless and a cooling fan. This is important. The cooling fan combined with low thermal conductivity stainless causes the melt transition region to become so much shorter, that SOME of the forces go sideways, but not all. For the forces that do go sideways, the polish helps reduce friction. In addition, a taper DOES not in fact help as I originally thought. Instead, it encourages filament to move "sideways" and causes clogging all the same. By contrast teflon has none of these problems.
I've tried alumina ceramic, kapton-coated aluminum, aluminum, stainless, wood, tapered metal holes, inverse tapered holes, and more. None of these work like the existing solutions.
So, what is so incredibly special about teflon that makes it work, without a cooling fan, and it completely resilient to getting stuck? Is it just the lower friction? What are the disadvantages? Does Peek work (as a lining material)? How about ultem? How about glass-filled teflon?
Why did people switch to all metal hot ends, and add a loud fan to the system, when teflon was working?
Measure once, Cut twice, Print 3 times.
Re: Is there any alternative to Teflon?
October 15, 2013 07:51PM
teflon is slippery and chemically inert , PLA bonds strongly with PEEK which is why it isnt used
October 15, 2013 07:57PM
People switched to all metal hotend for a variety of reasons mainly because you can take them to some really stupid temperatures in relative safety, (personally i've gone as high as 560c),
however... people in general have also expected pretty much all the all metal hotends to still be a general purpose hotend eg can extrude everything and have really been spolit by the jhead (which is still the benchmark).
realistically certain materials and sizes are better suite to particular types of hotends
> useless extruder.
> these problems.
> working?
-=( blog )=- -=( thingiverse )=- -=( 3Dindustries )=- -=( Aluhotend - mostly metal hotend)=--=( Facebook )=-
October 15, 2013 07:59PM
the metal hot ends are still described as experimental.
October 15, 2013 08:05PM
where? ... not all of them
October 15, 2013 08:32PM
You could try to experiment with nanocoatings. At least some of them are even oil repellend, which is similiar to molten plastic. Only if they can withstand the heat and how long the coating will last seems to be critical to me. But it wont cost much and you can apply the coating to any material fast and easy. Maybe there is a better suited coating for the high temperature purpose than this one here:
Nano Coating Video
Good luck!
Marcel
Blogs:
Meine 3D Druck Abenteuer
[3dptb.blogspot.de]
FLSUN Delta Drucker für Deutschland
[flsun-deutschland.blogspot.com]
Books on 3D patents:
[goo.gl] (english)
[www.amazon.de] (deutsch)
October 15, 2013 09:56PM
What makes PTFE so special is the fact that it has VERY low friction, low thermal conductivity, and can withstand relatively high temperatures (enough for ABS extrusion). It has all of the necessary characteristics of a hot end insulator. Hot end developers have yet to find a material that is a more effective than PTFE in this regard.
The only time PTFE is not used in hot end design is when we are trying to reach temperatures above ~240C to print Nylon/Polycarbonate as PTFE really starts to break down above this temp. This is why people have started designing "all-metal" hot ends.
Eric
October 15, 2013 11:07PM
PTFE is used as a non-stick coating for pans and other cookware, so if you find a pan that boast a different kind of non-stick coating then that might be an alternative to explore.
October 15, 2013 11:08PM
clever...
"where can I find a non stick coating, and heat"
Edited 1 time(s). Last edit at 10/15/2013 11:08PM by Simba.
October 16, 2013 02:00AM
Teflon still has the problem of creep. Especially for ABS temperatures, teflon will slowly widen and create leaky holes at the junction between cold and hot. This will result in plastic leakage around your hot end.
Even in the J head design, the teflon liner can still get squished over time and create a gap between the liner and the nozzle taper. This in turn will cause your hot end to become less responsive to retraction and increase oozing.
This is why most people are switching to all-metal designs because in my opinion they have none of the problems of teflon. The fact that it seems difficult to control the heat traveling up through the thermal break is just a technical detail that will soon be overcome once people realize you need proper cooling on the "cold end" and none of these microscopic 2-cm fans that E3D has made popular.
Maybe you could even chemically coat the inside of a stainless steel thermal break with teflon in exactly the same process used to coat stainless cooking pans. That would be the best design.
October 16, 2013 03:15AM
already looked into it, the cost is a little crazy
October 16, 2013 03:35AM
Graphite loaded PEEK sold as Tekapeek by RS 297-0147, £11.88 for 300mm of 10mm dia. I have tried this in the liner of a hot end but it was not a success -possibly for a reason unrelated to the material. i will try again in the future when I am not firefighting just to keep the damn thing running.
Mike
October 16, 2013 10:43AM
JGR
That's a pity sad smiley Teflon coated SS would be the perfect thermal break. Have you tried coating the filament in Teflon as it enters the hot end? I am not sure if this would be very effective but it's worth a try.
Eric
October 16, 2013 10:49AM
Yes it does if it covers all of the transition zone. It works like a mould relief taper. It prevents the rubbery part of the filament gripping the wall as any forwards movement causes it to part from the wall. Below the taper the filament is liquid and above it it is solid.
The all metal extruder I made (probably the first in the Reprap world) used stainless steel pipe which was not very smooth on the inside and certainly not polished. It worked well with PLA, ABS, PCL, PMMA and HDPE. It didn't work reliably before I added the taper.
October 16, 2013 10:51AM
RP Iron Man Wrote:
JGR
> of
> crazy
> worth a try.
> Eric
it's on the todo list,
October 16, 2013 11:11AM
Did it use a cooling fan?
Im on a mission against the cooling fan. They are too loud (try running 3 Up! printers side by side).
October 16, 2013 11:14AM
JGR
Ok, be sure to post your results here when you do get around to it. If coating the filament in Teflon works effectively enough, the manufacturing of all-metal hot ends would be made much simpler smiling smiley
Eric
October 16, 2013 11:21AM
Yes it needed a small fan but it wasn't noisy compared to the rest of the printer.
October 16, 2013 11:24AM
Interesting. I found that too, you are right that a taper helps, and that you need a fan to see there is difference between tape and not.
mechanically, I'm not sure why a ~5mm transition region is okay, but a 10mm transition = a total failure. You would think if the diameter of the stainless piece is 2 mm, that the forces would be absorbed easily within a 1:1 aspect ratio, maybe even over only 2mm of length.
So in conclusion for this thread, are we all agreeing that we think teflon works because of the low friction...If this was a navier stokes equation, the no slip condition on the wall is really small...
October 16, 2013 05:44PM
> really small...
there are other complex factors around the effectiveness of retraction in ptfe lined and non ptfe lined hotends particularly with ooze, this is one of my latest nozzles
click here
bear in mind that photo was taken 30minutes after the filament was retracted 10mm and the hotend left running at 190c , this somthing i did to test how viable this nozzle would be in a dual extruder setup, this is somthing that has never worked with an all metal setup
Edited 1 time(s). Last edit at 10/16/2013 05:46PM by thejollygrimreaper.
October 16, 2013 05:46PM
Could you repost that image?
Are you saying teflon is better for retraction?
That would agree with what I've found here, that metal has friction, its just lessened by fans, tapers, and polish... so if you try to retract the force on the walls should cause the retracted filament to just stretch rather than actually pull up.... interesting
October 16, 2013 06:47PM
When you retract the rubbery filament stretches lengthways and so pulls away from the walls and does not jam. This is why you can always pull PLA out even when it it not go forwards at all.
It is not a case of a bit more friction means a bit more force is required, There is a critical limit on the coefficient of friction and the length of the transition zone, above which it simply jams solid because of positive feedback. I.e. the more force you apply the more outward pressure you get so that multiplied by the coefficient of friction means you have an equal increase in grip, so it doesn't move.
October 16, 2013 08:39PM
And therefore the metal solution is to not change the coefficient of friction, but make this zone as short as possible?
Did the other printers (before darwin) use Teflon?
October 16, 2013 09:10PM
Printers before Darwin? Darwin was the first RepRap printer! It used PTFE for its slipperiness and good insulation. Unfortunately it also used it for structural strength, which was a mistake as it always fails due to creep. Hybrid PEEK / PTFE solved that problem.
As far as I can remember the only successful hot ends that have a long transition zone use PTFE. With any other material the transition must be short and that requires a fan or a big heatsink.
The Archol one uses a very thin wall stainless steel tube and that only has a small heatsink but possibly also needs a small fan and is very delicate.
Many combine the worst of both worlds and have stainless steel with a PTFE liner and a heatsink and a fan.
October 16, 2013 11:51PM
Seems like there is a whole world of high temp / low friction coatings:
http://industrialcoatingsworld.com/low-friction-coatings/
It would be interesting to experiment with some of these.
October 17, 2013 03:09AM
> [url=http://industrialcoatingsworld.com/low-fricti
> on-coatings/]http://industrialcoatingsworld.com/lo
> w-friction-coatings/[/url]
> these.
aside from cost most of them don't really have any temperature limits higher than ptfe tube anyway
October 17, 2013 04:57AM
I still think with all the hype about metal hot ends the general user needs to know to stay away from them. all of them are still considered experimental. none of them have a 100% track record, and all of them require extra parts, fans, calibration that a new user will likely not be familiar enough to handle.
October 17, 2013 05:03AM
a jhead needs a fan...
October 17, 2013 05:45AM
It's borderline. If the heater block is well insulated to stop convection and the carriage has holes to stop it trapping heat it works without a fan. I think the MK4 was better than the MK5 as I never had any problems with PLA in that without a fan.
October 17, 2013 07:48AM
What if there is a force down the pfte tube, if it creeps, the force just pushes the pfte tube further down. Thats the idea here, anyway. Of course, it would still widen, and so might the PLA which can cause problems retracting.(In the case of the j-head i use kapton/aluminium tape to limit the widening a bit. Also it helps that the walls become thicker; the inner radius expands less than the outer radius.)
Based on that i might try this idea.(I think it will probably leak though?)
Edited 1 time(s). Last edit at 10/17/2013 07:48AM by Jasper1984.
