So I print in ABS onto glass with ABS juice I have found it to be very sucsessful. I made a big batch of Black ABS juice with some failed prints and I wanted to make some White ABS juice. However it did not go into solution with the acetone, I hd no problem making a consistent mix with the black that I could adjust the viscosity of the mix by adding acetone till it was where I wanted it. With the white filament, there is a quasi-transparent jelly like mass at the bottom of my mason jar and a layer of Acetone floating above it. Is it possible to make ABS juice out of white filament?
Has anyone had a similar experience? I doubt I will be salvaging it, but any suggestions are helpful.
I should point out that the filament I used to make the juice was sitting around in the open for a few weeks so I dont know if it potentially oxidized or if that could have affected it.
I appreciate any feedback. Thanks!
