Required motor power November 23, 2013 01:56PM |
Re: Required motor power November 23, 2013 07:15PM |
Re: Required motor power November 23, 2013 07:38PM |
Re: Required motor power November 23, 2013 07:59PM |
Re: Required motor power November 23, 2013 08:37PM |
Dorian
I'm not sure why you find it curious that a smaller motor consumes less power. I may well be misunderstanding your inquiry.
[reprap.org]
Re: Required motor power November 24, 2013 02:59AM |
Re: Required motor power November 24, 2013 04:45AM |
Re: Required motor power November 24, 2013 06:17AM |
Re: Required motor power November 24, 2013 12:20PM |
Re: Required motor power November 24, 2013 04:55PM |
Re: Required motor power November 25, 2013 02:39AM |
output power requirements - masses, speeds, accelerations
Re: Required motor power November 25, 2013 04:24AM |
Re: Required motor power November 25, 2013 11:21AM |
iquizzle
Unfortunately, a lot of power is going to go into friction and that's not consistent between printers -- nor is it necessarily constant along the linear rod or consistent in time as bearings age, lose lubrication, even between two different LM8UUs due to sloppy manufacturing tolerances, etc. You probably can't operate a printer at the exact output power "required" because its not constant. Suppose the printer changes direction and becomes slightly misaligned and catches. Suppose it works when the bearings are brand new and then not once they wear in. To really do it well, measurement on the exact same system is probably what you have to do. Set something up to monitor the power over the course of a print and plot it.
Re: Required motor power November 25, 2013 12:00PM |
Robin2
@lobocnc, it looks like "nobody knows or cares".
Robin2
On the other hand if the project is successful why bother changing to a different type of motor? I'm guessing your motors will be more expensive but may allow greater speeds.
Robin2
But can the extruders cope with higher speeds? There seems to be no shortage of threads about extruder problems and extruder improvements.
Re: Required motor power November 26, 2013 08:03AM |
Re: Required motor power November 26, 2013 11:10AM |
Re: Required motor power November 26, 2013 12:38PM |
Re: Required motor power November 27, 2013 05:22PM |
Re: Required motor power November 27, 2013 06:01PM |
jamesdanielv
there was something interesting mentioned in this post. extrude issues and stalling could be detected. if it could then reliability of the machine would improve, however the feedstock usually stops feeding, and the motor shaft rarely stops. the place to control the extruder feedback should be somewhere else other than the motor.
Re: Required motor power November 28, 2013 05:18AM |
LoboCNC
Oh, I see what you are saying - why move the axes faster when extruders are already close to maxing out. I suppose if you are printing really thin layers, then you do want to move fast but the extrude rate is fairly low. For some of the all-metal hot ends that don't like extruding at low rates, you may actually want to move the axes faster to keep the extruder happy.
What I've gleaned from all of these comments, though, is that for the most part, the garden-variety printer wouldn't benefit much from closed-loop control, except for maybe the extruder which might be made more reliable.
Re: Required motor power November 28, 2013 09:26AM |
alj_rprp
However, did you look in the DIY CNC milling crowd like shapeoko ?
Here, the higher loads on axis make a closed loop system highly desirable.
