Re: Re: RadRacer builds a "BerryBot3D" February 22, 2014 02:47AM |
NewKidOnTheBlock
garylucas: Are you actually trying to say that I need to know how to use 3D model software first before I can build a 3D printer and start printing stuff? That's like saying I need to know how to write code before I can put together a computer tower LOL.
Anyway, back to business.
Rad Racer: How did you determine the proper distance from the edge of the platen to the side of the aluminum profile you gave the control-arms attached to. Is there specific length for the CF rods or is the length ok as long as it reachs all sides of the platen?
Re: Re: RadRacer builds a "BerryBot3D" February 22, 2014 04:13AM |
RP Iron Man
NewKidOnTheBlock
garyhlucas is right about the importance of using 3d modeling software. Your analogy was incorrect. Putting together a computer tower is analogous to assembling a pre-designed 3d printer with all of the parts and an assembly manual. On the other hand designing a 3d printer from scratch is much more work. Like all CNC equipment, everything has to line up perfectly. Also, it is hard to determine the exact dimensions of every measurement if you don't have a 3d model that you can play around with. Mistakes are bound to happen.
I'll say you should take his advice and invest in some 3d modelling software. It will be useful for your future projects as well
Eric
Re: RadRacer builds a "BerryBot3D" February 22, 2014 09:38AM |
Re: Re: RadRacer builds a "BerryBot3D" February 22, 2014 01:02PM |
NewKidOnTheBlock
I appreciate your honesty, Eric. I'm currently learning freecad and sketch. Any other good programs you would recommend I check out?
Re: Re: RadRacer builds a "BerryBot3D" February 22, 2014 01:11PM |
Re: RadRacer builds a "BerryBot3D" February 22, 2014 01:20PM |
Re: RadRacer builds a "BerryBot3D" February 22, 2014 01:54PM |
Rad Racer
It's a winter wonderland!
The mid-west has been getting pounded this winter, lots of cold and snow. We haven't seen this since the 80's....so much for that global warming theory For most the winter we have been just walking through the snow to get to the shop, after the snow yesterday it just got too deep so we gave the snow blower a bit of a workout.
Sure makes for a nice walking path.
Re: RadRacer builds a "BerryBot3D" February 22, 2014 02:50PM |
Re: RadRacer builds a "BerryBot3D" February 22, 2014 03:27PM |
NewKidOnTheBlock
Wayne: Thanks for answering my question.
Eric: Not everyone has access to expensive software and knows how to 3D model, and despite all that great things are still made by those people. I'm not arguing that learning how to utilize software to assist in 3D modeling isn't a good thing, I'm simply stating that believing that you absolutely must know how to 3D model via software first before building something isn't necessarily correct; because that would be like saying that you can't build something correctly/properly if you don't know how to 3D model what you're aiming to build first.
MaralB: Thanks for sharing
Re: RadRacer builds a "BerryBot3D" February 22, 2014 04:37PM |
Re: RadRacer builds a "BerryBot3D" February 22, 2014 09:05PM |
Re: RadRacer builds a "BerryBot3D" February 23, 2014 10:58AM |
Re: RadRacer builds a "BerryBot3D" February 23, 2014 01:59PM |
Re: RadRacer builds a "BerryBot3D" February 23, 2014 03:15PM |
Re: RadRacer builds a "BerryBot3D" February 23, 2014 04:15PM |
Re: RadRacer builds a "BerryBot3D" February 23, 2014 04:47PM |
Re: RadRacer builds a "BerryBot3D" February 23, 2014 05:02PM |
Re: RadRacer builds a "BerryBot3D" March 23, 2014 11:01AM |
Re: RadRacer builds a "BerryBot3D" March 24, 2014 07:47PM |
Re: RadRacer builds a "BerryBot3D" March 25, 2014 10:28AM |
Rad Racer
I am not sure of Werner's plans to release parts or machines.
I do know there was discussion about starting a users group.....but again I do not have any updates or details.
Many have said they are intimidated by the end effector bends and dumples. If you look at my buildlog photos you can see I did it with some basic tools (a brake, angle finder and a simple press) no problem.
All in all, the machine is quite easy to clone, there are no tricky dimensions or funky cuts. Granted a cnc router or mill makes life much easier but if you have access to the tools at work I would go for it and build the machine.
I had mine down at the Midwest RepRap Fest, folks seemed to like the machine.
There were a ton of comments about the print speed and over all print quality.
Wayne
Re: RadRacer builds a "BerryBot3D" March 25, 2014 05:53PM |
Re: RadRacer builds a "BerryBot3D" April 11, 2014 01:58PM |
Re: RadRacer builds a "BerryBot3D" April 12, 2014 10:26PM |
Re: RadRacer builds a "BerryBot3D" April 15, 2014 11:28PM |
Re: RadRacer builds a "BerryBot3D" April 16, 2014 08:27AM |
Re: RadRacer builds a "BerryBot3D" April 16, 2014 08:20PM |
Re: RadRacer builds a "BerryBot3D" April 17, 2014 02:04AM |
Re: RadRacer builds a "BerryBot3D" April 17, 2014 08:49AM |
Re: RadRacer builds a "BerryBot3D" May 08, 2014 07:38PM |
Re: RadRacer builds a "BerryBot3D" May 25, 2014 01:29PM |
