more flexible timing belt November 30, 2013 04:34PM |
Re: more flexible timing belt November 30, 2013 05:16PM |
Re: more flexible timing belt November 30, 2013 07:29PM |
Re: more flexible timing belt November 30, 2013 09:56PM |
Re: more flexible timing belt November 30, 2013 09:57PM |
Re: more flexible timing belt November 30, 2013 10:02PM |
Re: more flexible timing belt December 01, 2013 12:39PM |
iquizzle
I also think that gt2 is generally the best timing belt technology for 3d printing.
Re: more flexible timing belt December 01, 2013 01:39PM |
Re: more flexible timing belt December 01, 2013 06:19PM |
iquizzle
but I also think that gt2 is generally the best timing belt technology for 3d printing.
Re: more flexible timing belt December 01, 2013 10:51PM |
makeme
The point is finding a linear motion transmission system that can work in more than one plane. Belts are great if the axis of all of the bends are parallel, but if they're not, then it doesn't matter how great the belt is because it can't go where it needs to go.
After looking at the synchromesh it turns out they don't have an endless loop option, so that won't work. Maybe beaded chain or braided fishing line.
alj_rprp
T2.5 has as good backlash behaviour as GT2, is mostly shrugging grime and its reinforced backside will keep tensions more even if env temps and especially humidity vary.
T2.5 also costs about nothing when compared to GT2. Gates marketed very heavily the GT2 but there is a lot of BS in their arguments
Re: more flexible timing belt December 01, 2013 11:09PM |
garyhlucas
You actually can drive timing belts around corners. They easily twist 90 degrees to go off in a different direction, then twist back 90 degrees. So they can bend 180 degrees around an intermediate set of pulleys.
Re: more flexible timing belt December 02, 2013 03:37AM |
iquizzle
I really haven't encountered any grime in my belts even after 2 years of printing, but it's an interesting point and I'll think about that in choosing belts for my shapeoko. Really, I've been quite happy with GT2 and compared to MXL and HTD, they are significantly less prone to slipping. Considering that all of these belts/pulleys are pretty much the same price, I don't think it's worth buying MXL or HTD. My statement that GT2 is generally the best belt is based that they are rated for a smaller radius of curvature compared to T2.5, making them more useable in a larger variety of environments. There is also a much larger selection of pulleys available.
Re: more flexible timing belt December 02, 2013 10:02AM |
Re: more flexible timing belt December 03, 2013 11:27AM |
Re: more flexible timing belt December 03, 2013 04:20PM |
ShadowRam
You're not talking about this stuff?
[precisionparts.wmberg.com]
I have it on my repstrap. It's pretty good stuff.
Re: more flexible timing belt December 04, 2013 10:13AM |
Re: more flexible timing belt December 04, 2013 11:46AM |
Re: more flexible timing belt December 04, 2013 12:04PM |
makeme
I could have sworn I saw a few projects that were using some kind of timing belt that looked like a spiral around a wire so that it could bend in any direction, not just in two dimensions. Now I can't find anything like that. Does a spiral timing belt sound familiar to anyone?
