Strange behavior with X loosing steps December 01, 2013 08:15AM |
Re: Strange behavior with X loosing steps December 02, 2013 04:15AM |
Re: Strange behavior with X loosing steps December 02, 2013 05:08PM |
Re: Strange behavior with X loosing steps December 03, 2013 01:41PM |
Re: Strange behavior with X loosing steps December 04, 2013 03:03AM |
Re: Strange behavior with X loosing steps December 04, 2013 06:16AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Strange behavior with X loosing steps December 04, 2013 09:21AM |
Re: Strange behavior with X loosing steps December 04, 2013 09:27AM |
Re: Strange behavior with X loosing steps December 04, 2013 06:13PM |
Re: Strange behavior with X loosing steps December 05, 2013 06:20AM |
Re: Strange behavior with X loosing steps December 05, 2013 06:41AM |
Re: Strange behavior with X loosing steps December 05, 2013 07:29AM |
Re: Strange behavior with X loosing steps December 05, 2013 07:48AM |
Re: Strange behavior with X loosing steps December 05, 2013 08:46AM |
Re: Strange behavior with X loosing steps December 05, 2013 09:21AM |
Re: Strange behavior with X loosing steps December 06, 2013 01:50AM |
Re: Strange behavior with X loosing steps December 06, 2013 02:27PM |
Re: Strange behavior with X loosing steps March 14, 2014 05:40AM |
Re: Strange behavior with X loosing steps March 14, 2014 08:16AM |
Re: Strange behavior with X loosing steps March 14, 2014 08:24AM |
Re: Strange behavior with X loosing steps March 14, 2014 10:42AM |
I agree it's probably mid band resonance if you'd put vibration dampers on the stepper motors it probably would've been okay. You definitely should use shielded cables if you going to run a high pulse rate you get all sorts of EMI. Secondly if your GT2 pulley per turn is less than 25 mm then you have more of a mechanical advantage which would allow you have more power to the axis per the same motor. I use ballscrews on my printer and it produces fantastic resultsQuote
nophead
The reason is lead screws suffer from mid band resonance but belt drives don't.
Re: Strange behavior with X loosing steps March 14, 2014 11:52AM |
Re: Strange behavior with X loosing steps March 14, 2014 06:59PM |
Re: Strange behavior with X loosing steps March 14, 2014 10:29PM |
