Nozzle end shape. December 10, 2013 05:48AM |
Re: Nozzle end shape. December 10, 2013 06:19AM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Nozzle end shape. December 10, 2013 06:29AM |
Re: Nozzle end shape. December 10, 2013 06:34AM |
Re: Nozzle end shape. December 10, 2013 02:27PM |
Re: Nozzle end shape. December 10, 2013 05:24PM |
Re: Nozzle end shape. December 11, 2013 03:39AM |
Re: Nozzle end shape. December 12, 2013 05:00PM |
Did you try to make your nozzle stainless steel?Quote
Srek
During development of my Merlin Hotend i tried various nozzle shapes. What it boiled down to for me was that flatter nozzles make it easier to produce smooth top layers, but have difficulties printing good bridges. Sharp pointed nozzles, like the airbrush nozzles i use mostly nowadays, can print beautiful bridges, but need more precise calibration to create smooth surfaces.
Re: Nozzle end shape. December 12, 2013 09:47PM |
Re: Nozzle end shape. December 13, 2013 04:59AM |
Yes, but i did not follow that route further since i did not see any advantage. Steel is much harder to machine with my equipment and it distributes heat much worse than brass. From the few tests i did it seems that the actual material of the nozzle does not have nearly as much impact as the shape.Quote
karabas
Srek
Re: Nozzle end shape. December 14, 2013 10:37AM |
I see you chamfered nozzle about 45 degrees so the flats around orifice are about 0.1-0.15mm. Do you recommend such mod?Quote
thejollygrimreaper
here's a photo showing the small flat on the nozzles i put on my hotends, also you'll notice the inside the orifice is chamferd slightly (this took care of burrs) and seems to give me some very nice print quality that a 0.8mm diameter flat around a 0.3mm hole,
https://www.dropbox.com/s/czb9culzsnqntlz/_DSC9114.JPG
ignore the other stuff in the photoo ...
Re: Nozzle end shape. December 14, 2013 10:54AM |
Re: Nozzle end shape. December 14, 2013 11:30AM |
Re: Nozzle end shape. January 19, 2014 05:21AM |
