Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 01:29PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 01:33PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 02:13PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 03:37PM |
T3P3
The diameter of the filament does not have a direct influence on the extrusion force at the nozzle as the plastic is molten. It can make a difference further up the path though. It varies by hotend design for example the length of the transition zone.
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 04:05PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 05:08PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 05:34PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 06:55PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 08:10PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 08:37PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 14, 2014 02:23AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 14, 2014 04:03AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 14, 2014 07:43AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 14, 2014 01:59PM |
Ohmarinus
Yvan
How about grooving the bearings yourself? It's easy.
I tried with my Dremel, no luck. Those bearings are superhard!
Re: Filament diameter - differences between 1.75mm and 3.0mm January 15, 2014 03:27PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 15, 2014 04:09PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 15, 2014 04:16PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 15, 2014 04:44PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 15, 2014 04:45PM |
