MAGMA hotend ANTI-CLOGGING solution December 14, 2013 03:16PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 14, 2013 04:38PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 14, 2013 08:41PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 15, 2013 07:31PM |
Anonymous User
Re: MAGMA hotend ANTI-CLOGGING solution December 15, 2013 08:10PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 16, 2013 07:58AM |
Re: MAGMA hotend ANTI-CLOGGING solution December 16, 2013 07:11PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 16, 2013 09:22PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 16, 2013 09:52PM |
Admin Registered: 12 years ago Posts: 1,063 |
extent
The Magma is a rebranded 3mm all metal Aluhotend
Re: MAGMA hotend ANTI-CLOGGING solution December 16, 2013 11:57PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 17, 2013 01:18AM |
nechaus
how do you think it would go converting my alu hotend to a all metal one?
It does have a ptfe liner so if I took it out, there would be about 1mm gap...
using a budaschnozzle atm, works very well... but I don't want to take it up to 300c... I got to about 240-260 at the very max
Re: MAGMA hotend ANTI-CLOGGING solution December 17, 2013 02:12AM |
Re: MAGMA hotend ANTI-CLOGGING solution December 17, 2013 02:16AM |
Re: MAGMA hotend ANTI-CLOGGING solution December 17, 2013 10:36PM |
Anonymous User
Re: MAGMA hotend ANTI-CLOGGING solution December 17, 2013 10:51PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 17, 2013 10:55PM |
Re: MAGMA hotend ANTI-CLOGGING solution December 18, 2013 01:37AM |
nechaus
hey guys, thought id post some pics of my aluhot end,
Do you think its possible to just take out the ptfe line and crank up the heat to 290 and use it with nylon ?
here are some pictures of it
Re: MAGMA hotend ANTI-CLOGGING solution December 18, 2013 02:45AM |
Re: MAGMA hotend ANTI-CLOGGING solution December 18, 2013 02:57AM |
nechaus
bugger, I wont bother then, is there anything you could think of that might work?
could i go crazy with cooling the heat sink and try 280c ?
does the liner go all the way down?
Re: MAGMA hotend ANTI-CLOGGING solution December 18, 2013 11:48AM |
Re: MAGMA hotend ANTI-CLOGGING solution December 18, 2013 06:15PM |
Re: MAGMA hotend ANTI-CLOGGING solution January 15, 2014 10:09PM |
Re: MAGMA hotend ANTI-CLOGGING solution January 15, 2014 10:15PM |
