Problem with Sanguinololu December 28, 2013 11:03PM |
Re: Problem with Sanguinololu December 29, 2013 01:16AM |
Re: Problem with Sanguinololu December 29, 2013 04:28AM |
Re: Problem with Sanguinololu December 29, 2013 12:01PM |
Re: Problem with Sanguinololu December 29, 2013 02:15PM |
Re: Problem with Sanguinololu December 31, 2013 05:05AM |
Re: Problem with Sanguinololu December 31, 2013 05:39AM |
Siemann
Today, after a difficult and hard work, i finded solution for my problem...
1. I asked my friend to clear fuse bit by Atmega fusebit doctor.
2. Flash bootloader from "http://reprapuniverse.com/files/Merlin_i3.zip" by ISP parallel programmer FBPRG and AVReAl program.
Fuse: Low 0xD6
High 0xDC
Ext 0xFD
3. I am install Arduino 1.0.5 and Arduino addons from [github.com]
4. In Arduino workspace i am select "ATmega1284p 16mhz ceramic resonator"
and Marlin.pde from [github.com]..
5. Use Pronterface Printrun-Win-Slic3r-05Nov2013.zip from [koti.kapsi.fi]
This is result)) [cs425526.vk.me]
But LCD don't work... and message bug ":Extruder switched off.MINTEMP triggered! "...
I think reprapuniverse wrong flash fw in controller by [reprapuniverse.com] firmware, because file board.txt from code.google.com/p/sanguino/downloads/detail?name=Sang..
contain:
#atmega1284.build.mcu=atmega1284p
#atmega1284.build.f_cpu=8000000L
#atmega1284.build.core=arduino
Re: Problem with Sanguinololu December 31, 2013 09:42AM |
//// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup) #define TEMP_SENSOR_0 1 //for J-head hotend with EPCOS #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1 //for PCB heatbed Mk2 with EPCOS
