heat shrink tubing for nema17 wire?
January 09, 2014 11:45AM
where and what size of heat shrink tubing to get for nema17 stepper motors?
tia
Re: heat shrink tubing for nema17 wire?
January 09, 2014 05:18PM
I just got a box with a lot of different sizes, then I have crimped and shrink-wrapped all little wires I do one bigger one over the four wires together so they don't stray. Play around winking smiley
January 09, 2014 09:36PM
Twist the wires in a tight spiral before heat shrinking them. Helps reduce electrical noise by the wires canceling each other.
January 09, 2014 09:56PM
i plan to solder them and then heat shrink to cover each wire, but don't know what tubing size to purchase. I see kit which have variety of size but don't know if the size i need will be enough and have extra of those i won't use.
January 10, 2014 01:21AM
I've just bought a large package of 2 mm ID heat shrink tubing for use with stepper motor wiring. 2.5 mm ID might also work well I think.
Yvan
Singularity Machine
January 11, 2014 05:40PM
In general heat shrink tubing will shrink to 50%
