DIYtechshop Bad Experiences January 12, 2014 11:47AM |
Re: DIYtechshop Bad Experiences January 12, 2014 12:22PM |
Anonymous User
Re: DIYtechshop Bad Experiences January 12, 2014 08:05PM |
Re: DIYtechshop Bad Experiences January 12, 2014 08:21PM |
Re: DIYtechshop Bad Experiences January 13, 2014 01:47AM |
Re: DIYtechshop Bad Experiences January 22, 2014 05:17PM |
Re: DIYtechshop Bad Experiences January 24, 2014 02:27PM |
Re: DIYtechshop Bad Experiences January 27, 2014 03:09PM |
Re: DIYtechshop Bad Experiences January 27, 2014 07:22PM |
Re: DIYtechshop Bad Experiences January 27, 2014 07:41PM |
Re: DIYtechshop Bad Experiences January 28, 2014 12:10AM |
Re: DIYtechshop Bad Experiences January 28, 2014 12:23PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: DIYtechshop Bad Experiences January 28, 2014 02:42PM |
Re: DIYtechshop Bad Experiences January 28, 2014 02:47PM |
Admin Registered: 17 years ago Posts: 1,472 |
Ohmarinus
jermac17 and Doug1 seem to be the same persons, both bought on 10th of Dec etc. Besides that, I agree, it's smelling of someone trying to make them look bad.
Re: DIYtechshop Bad Experiences January 28, 2014 02:55PM |
Re: DIYtechshop Bad Experiences January 28, 2014 03:46PM |
Re: DIYtechshop Bad Experiences January 28, 2014 03:50PM |
Re: DIYtechshop Bad Experiences January 28, 2014 10:00PM |
Re: DIYtechshop Bad Experiences January 29, 2014 10:31AM |
Re: DIYtechshop Bad Experiences January 29, 2014 11:12AM |
Re: DIYtechshop Bad Experiences January 29, 2014 03:45PM |
NewPerfection
Ohmarinus
They do at least have different IP addresses.
Posts from brand new users do need to be taken with a grain of salt, but baseless accusations aren't helpful either.
Re: DIYtechshop Bad Experiences January 29, 2014 05:15PM |
Re: DIYtechshop Bad Experiences February 01, 2014 07:48PM |
Through self sustaining actions comes freedom
Re: DIYtechshop Bad Experiences February 03, 2014 01:14PM |
Doug1
Ok first I am sure who ever runs this board can do a fast ip search and figure that out one person isnt just being mean.
Now falwty99 the X end stop worked ok for me with the zip tie plan(that said i had to solder the wires on because there isnt enough room to fit the connector between the bottom of the end stop and the ground ). Y end stop i ended up micro drilling and putting a screw though the plastic on y-0 side to hold it. - Works for now..
Z i used a hand cut piece of sterophome and some good old fassioned duct tape to hold together until i could print an endstop mount
file available here - [github.com]
- The LCD problem im still dealing with strange that you are as well, Mine seems ok as long as its got usb power but doesnt self power anymore. My next plan is to try a usb wall charger.
- Additionally since the excruder head moves when it gets plastic forced into it i use an m8 washer hold that in place but its alittle fun to thead after that.
- See attached picture it should help as well. - Wireing diagram that helped me allot. d9 is actually where your fan goes. Thank the reprap irc gods for that tidbit.
edit: also going to add in here they did send me the wrong firmware make sure you have the version with lcd support.
Re: DIYtechshop Bad Experiences February 03, 2014 02:04PM |
Re: DIYtechshop Bad Experiences February 03, 2014 02:56PM |
Doug1
I actually went to the reprap site and refrenced every componet on the board and yea its there. I am thinking something happned to it.
I supply it with a 12v / 15a power supply i got from rat shack and im pretty sure it worked for a short period of time. Really at this point i could care less about the darn thing although some day i will want it to work on its own.
Question for anyone out there is can i just use a usb to wall plug ( aka phone charger ) to power the lcd when its not attached ?
Re: DIYtechshop Bad Experiences February 03, 2014 04:22PM |
Re: DIYtechshop Bad Experiences February 03, 2014 07:26PM |
Doug1
The problem is that the lcd i not getting power meaning i can turn on the power supply and it doesnt light up. Add usb and it lights right up.
So basically to print and use the lcd i have to have my 12v / 15 amp connected to both main power screws the 11amp and 5 amp. So im going to gather that something burned somwhere since it only worked for like an hour before it died and had to have usb plugged in to light up.
Re: DIYtechshop Bad Experiences February 21, 2014 02:31AM |
Re: DIYtechshop Bad Experiences February 21, 2014 07:35AM |
ciutateivissa
The provide firmware does not meet the reqirements on the printer (e.g. LCD) and there was no answer to my email from DIY Tech Shop whe I asked kindly for some support.. With a lot of help from some forum members here in this forum I finally got the printer nearly working, but failed to print so far. But I know now, that some parts are not working.
