M501 To RAMPS And Not Responded
Posted by jpan
January 23, 2014 11:03PM
Hi guys
I am using repetiter-host and printrun sometimes to operate my Mendel i2. Unfortunately, when I wanted to see my parameters from EEPROM using gcode m501, it didn't respond. Neither repetiter nor printrun worked. The motors moved all right so the RAMPS probably has received the code.
Why?
It DID return the numbers with my old printrboard...
Thanks.
Re: M501 To RAMPS And Not Responded
March 20, 2014 10:23PM
Which firmware are you use on you board? M-code is firmware specific so we'll need to know which you're running to properly diagnose.
Through self sustaining actions comes freedom
DIY Tech Shop
March 21, 2014 01:28AM
eeprom commands also has to be enable in firmware
eg see [github.com]
March 21, 2014 10:12AM
Sprinter is the firmware that i am using.
March 22, 2014 12:49AM
needs to be turned on then [github.com]
Is defiantly supported in sprinter
March 24, 2014 10:17PM
Thanks. Problem solved!
