High Speed Printing February 14, 2014 05:58PM |
Re: High Speed Printing February 14, 2014 07:08PM |
Re: High Speed Printing February 14, 2014 07:16PM |
Re: High Speed Printing February 14, 2014 07:20PM |
Re: High Speed Printing February 14, 2014 11:20PM |
Re: High Speed Printing February 15, 2014 12:46AM |
Anonymous User
Re: High Speed Printing February 15, 2014 12:53AM |
Re: High Speed Printing February 15, 2014 02:39AM |
Re: High Speed Printing February 15, 2014 08:12AM |
Re: High Speed Printing February 15, 2014 09:19AM |
Re: High Speed Printing February 15, 2014 11:50AM |
Re: High Speed Printing February 15, 2014 03:55PM |
Re: High Speed Printing February 15, 2014 04:48PM |
DonaldJ
I don't care that much about crazy-fast speed; it was the smoothness of direction changes that got me.
With the TinyG, it looks like infills of narrow parts would be very smooth and create less vibration and stress to the machine.
That should contribute to better quality parts, even without uber-speed, no?
9000mm/s^2 max acceleration 3000mm/s^2 default acceleration 20mm/s jerk 45mm/s perimeter 90mm/s infill. 300mm/s travel.
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: High Speed Printing February 17, 2014 07:23AM |
Re: High Speed Printing February 17, 2014 11:39AM |
Bill I guess it's all in what you want or need but for me personally that print that he showed printed at 500 mm a second is not up to my standardsQuote
cnc dick
Bill I guess it all depends on the quality that you want or need like that YouTube video at 750 mm second he doesn't give you a close-up of the part he printed at that speed. We all know moving things around at that speed is possible printing nicely is another story I will will keep an eye out on that tiny G and see how that turns out
Re: High Speed Printing February 21, 2014 11:12PM |
Yes, I'm starting to get my head around this. I do believe we will migrate towards faster and faster print speeds. Seems like a natural progression. I have absolutely been swimming in all this stuff trying to get up to speed. Very excitingQuote
cnc dick
Bill I don't think you'd be happy with the results of anything printing like that I know you come from machinist background and the prints at that rate of speed are terrible at the moment plastic filament can not be laid down that fast with good results. Plus the threaded rod machine you can see all of its shortcomings flexing all over the place terrible. 3-D printers were originally designed for one up prototypes the guy working with tiny G is probably working with the accelerations the problem with that being from what I've found is so far is you need to have good fast acceleration and deceleration for prints if you reduce this you can achieve that speed but the print is not going to be good notice he's not printing
Re: High Speed Printing February 21, 2014 11:17PM |
Synthetos (TinyG) are very hard at work pushing the envelope (mainly with milling/routers) but have a new version coming out (the V9) which is going to be very powerful/versatile. Riley didn't give me specifics but when I presented my desire to build a machine that prints and mills with more than just XYZ he said this would be the ticket. Thanks again for the link. It put me on the path I wanted to go onQuote
DonaldJ
You'll want to look at this, too: [www.youtube.com]
The developer, Alden Hart, spoke at the local hackerspace recently and said that the Ultimaker was sitting on a hard tabletop and didn't move or wobble at all.
It was all in the Tiny G controller, and how it handled jerk and acceleration.
Way cool.
Re: High Speed Printing February 22, 2014 12:36AM |
Re: High Speed Printing February 22, 2014 02:57AM |
Bill Clark
cnc dick
Re: High Speed Printing February 22, 2014 08:51AM |
that is great advice but just not me. I jump in the deep end and learn to swim (usually painful) . I did buy a assembled machine for initial learning curve however.Quote
vegasloki
Bill Clark
cnc dick
The best way to shorten your learning curve is to build a low cost entry level machine and use that as a starting point. Regardless of any experience with subtractive machine tools additive manufacturing has elements that are best learned from building a small machine first .
