Narower 12 Volt power supplies? February 17, 2014 04:34PM |
Re: Narower 12 Volt power supplies? February 17, 2014 04:48PM |
Re: Narower 12 Volt power supplies? February 17, 2014 05:25PM |
Re: Narower 12 Volt power supplies? February 17, 2014 05:36PM |
Re: Narower 12 Volt power supplies? February 17, 2014 06:01PM |
Re: Narower 12 Volt power supplies? February 17, 2014 06:02PM |
Re: Narower 12 Volt power supplies? February 17, 2014 06:10PM |
Re: Narower 12 Volt power supplies? February 18, 2014 05:56AM |
Re: Narower 12 Volt power supplies? February 18, 2014 09:43AM |
Re: Narower 12 Volt power supplies? February 19, 2014 02:21AM |
Re: Narower 12 Volt power supplies? February 20, 2014 11:51PM |
Re: Narower 12 Volt power supplies? February 21, 2014 08:55AM |
It may not be a consideration, but optimal efficiency of the power supply usually is obtained when the required output is near the designed output. That doesn't mean if you need 300 watts to get exactly a 300 watt power supply. But getting a 835 watt supply is overkill, and you'll be losing efficiency over say a 350 or 400 watt supply.Quote
REPRAP SQUAD
The amperage doesn't matter if you have more than needed because it will only use what it needs so having extra amperage is a good thing. Having the extra makes your power supply not work as hard as one with barely enough amps, which will help your PSU last longer.
