LCD menu wont scroll down February 18, 2014 10:44PM |
Re: LCD menu wont scroll down February 19, 2014 01:19AM |
Re: LCD menu wont scroll down February 19, 2014 07:52AM |
jamesdanielv
is there a setting for how many lines are displayed with this controller?
have you looked at the lcd layout menu pdf file inlcuded in marlin file to know what options are available for lcd display?
are you using a delta bot, which has some features disabled?
Re: LCD menu wont scroll down February 19, 2014 10:45PM |
Re: LCD menu wont scroll down February 20, 2014 01:15AM |
Re: LCD menu wont scroll down February 20, 2014 07:55AM |
Re: LCD menu wont scroll down February 20, 2014 11:09AM |
Re: LCD menu wont scroll down February 20, 2014 11:28AM |
Re: LCD menu wont scroll down February 20, 2014 08:36PM |
Re: LCD menu wont scroll down February 20, 2014 08:50PM |
jamesdanielv
do you think you can zip and upload your complete marlin firmware as is,
then someone can look at the code and see if there is anything in the code or a setting that is causing this to happen?
I'll try to look at it a little if it is uploaded by tonight sometime.
as for the buffering,
likely this would be a software buffer on arduino to the lcd display. I'd need to look at the code to find out more.
(link to zip file in my dropbox) : https://www.dropbox.com/s/azux1upon60goop/Marlin-Marlin_v1_2014-02-09.zip|
Re: LCD menu wont scroll down February 21, 2014 06:42AM |
Re: LCD menu wont scroll down February 21, 2014 08:05AM |
jamesdanielv
have you looked at reprap discounts version of marlin they say works with the display?
[docs.google.com]
it is a start.
the wiring is different for the menzi versus a ramps board. different pins are used for the encoder wheel, and for the lcd.
//Pins for 4bit LCD Support ramps
#define LCD_PINS_RS 16
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 23
#define LCD_PINS_D5 25
#define LCD_PINS_D6 27
#define LCD_PINS_D7 29
vs menzi
#define LCD_PINS_RS 14
#define LCD_PINS_ENABLE 15
#define LCD_PINS_D4 30
#define LCD_PINS_D5 31
#define LCD_PINS_D6 32
#define LCD_PINS_D7 33
so far that is the only difference i see in the pins.h file. there are also differences in how it displays data for dot matrix displays the menus. still diging. but try the code linked above first. and also can you provide the exact name of the control chipset used for lcd?
Re: LCD menu wont scroll down February 21, 2014 08:18AM |
Re: LCD menu wont scroll down February 21, 2014 08:21AM |
Re: LCD menu wont scroll down February 21, 2014 08:27AM |
vreihen
Here is a link to my complete Marlin build from a few weeks ago for the Sainstore Megatronics 2.0 with the Sainstore version of the RRD full graphics 12864, along with the exact u8glib libraries that I used:
http://ae3.homelinux.net/marlin_megatronics2_lcd12864.zip
The U8glib folder was copied from my C:\Program Files\Arduino\libraries\ directory, and was downloaded a few weeks ago from the official source link included in whatever instructions I was following.
Note that I have not configured Marlin for any printer yet, other than copying over the Delta template. I just wanted to see the LCD-12864 interface difference between Marlin and Repetier, and never finished configuring Marlin beyond this. Since the LCD scrolls both ways on the same hardware that yours doesn't, I figured that I would share it so that you can see how yours differs.
If you decide at some point to go with Repetier, note that the LCD-12864 on a Megatronics 2.0 board doesn't work when compiled from their 0.91 web configuration builder tool. I had to do a hack job on one of the UI files to define the correct interface pins for the LCD and rotary encoder to work, and still don't think that I have the SD card working fully yet. I'll gladly share that build as well should someone with a Megatronics 2.0 and LCD-12864 need it for a reference.....
Re: LCD menu wont scroll down February 21, 2014 08:30AM |
[Solved] Re: LCD menu wont scroll down February 21, 2014 10:15PM |
#ifdef ULTIPANEL
// #define NEWPANEL //enable this if you have a click-encoder panel
#define SDSUPPORT
#define ULTRA_LCD
#ifdef DOGLCD // Change number of lines to match the DOG graphic display
#define LCD_WIDTH 20
#define LCD_HEIGHT 5
#else
#define LCD_HEIGHT 4
#endif
#else //no panel but just lcd
#ifdef ULTRA_LCD
#ifdef DOGLCD // Change number of lines to match the 128x64 graphics display
#else
#define LCD_WIDTH 16
#define LCD_HEIGHT 2
#endif
#endif
#endif
