three-point vs four-point mounting for MK2 heated bed February 19, 2014 02:14AM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 09:11AM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 11:06AM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 12:01PM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 01:22PM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 02:35PM |
KingRahl
Corkboard?!! That sounds waaay too soft and flexible. If you had your bolts going through it, then no wonder you were getting movement. Try a thin sheet of plywood or MDF.
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 03:57PM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 04:54PM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 05:08PM |
Re: three-point vs four-point mounting for MK2 heated bed February 19, 2014 07:17PM |
Re: three-point vs four-point mounting for MK2 heated bed February 20, 2014 08:23AM |
KingRahl
So your bolts connecting to the Y-frame are leading directly to the Heatbed holes? I guess it depends on the Y-carriage design you are using.
The 3 bolt method is not for the 4 PCB holes. It is for a stabilizing plate/board under your PCB. 2 on one side and the third in the middle of the opposite side. You wouldn't drill a hole through the middle of the PCB heatbed edge to get that 3rd hole (I hope).
Re: three-point vs four-point mounting for MK2 heated bed February 20, 2014 09:08AM |
Re: three-point vs four-point mounting for MK2 heated bed February 20, 2014 11:43AM |
Re: three-point vs four-point mounting for MK2 heated bed February 20, 2014 01:19PM |
KingRahl
I have about 6 MK2 heatbeds (this one says Manufactured by Avanti Circuits). Not one of them has a third hole, on any edge. I guess it depends on where you ordered yours from. Mine have the four corner holes, 1 center thermistor hole, 2 holes for the wire, and 6 smaller holes in between for resistor and LEDs. My traces go along the edges and around the mounting holes. No room to drill.
Re: three-point vs four-point mounting for MK2 heated bed February 20, 2014 07:13PM |
