my hotend can't reach 240° March 09, 2014 11:56AM |
Re: my hotend can't reach 240° March 09, 2014 12:09PM |
Re: my hotend can't reach 240° March 09, 2014 01:12PM |
Re: my hotend can't reach 240° March 09, 2014 01:16PM |
jaak lab
it's a magma hotend 40W
i usually use ABS
Re: my hotend can't reach 240° March 09, 2014 02:36PM |
Admin Registered: 11 years ago Posts: 3,096 |
RP Iron Man
jaak lab
i usually use ABS
Could be a fluke heater cartridge.
Most heater cartridges come from China and many of them have incorrect specifications. I would just save yourself the trouble and replace it with a through hole resistor heater from DigiKey.
EDIT: a 4.7ohm through hole resistor heater will provide ~30W at 12V which should be more than enough. I have used this one from digikey and it works great. It only costs 85 cents...
Eric
Re: my hotend can't reach 240° March 09, 2014 03:18PM |
Ohmarinus
RP Iron Man
Eric
Hi Eric, how long does it take to get to 200º with that through-hole resistor?
I am now using a ceramic cartridge, but I reckon it might be better to use a resistor so I can insulate my hotend better. However, if it takes 6 minutes or something, then I'll stick with what I got. Now it's on temp in about 1 minute.
Re: my hotend can't reach 240° March 09, 2014 03:34PM |
Re: my hotend can't reach 240° March 09, 2014 05:49PM |
RP Iron Man
Ohmarinus
RP Iron Man
Eric
Hey Marinus,
Heating times are dependent on the heat capacity of the "melt-zone" in question. This is a function of the mass and material used (aluminium, brass, etc...).
I use this 4.7ohm resistor for my Prometheus Hot End and using a standard MZ length of about 16mm (material is aluminium though mass is less than most hot ends) it heats above 200C in less than 1 minute. I think 30W is easily enough even for a larger MZ. If you want it to heat up lightning fast you can use a resistor with lower resistance though I would not recommend it as these through hole resistor are already used over the rated capacity. I don't think you should go over 30W.
Eric
Re: my hotend can't reach 240° March 09, 2014 07:36PM |
Ohmarinus
Okay, that sounds pretty good.
But, on the site of digikey it says the resistor is 3W?
How do you get to 30W?
Oh, and I can't find a seller besides digikey. I am in Europe and Digikey rates me around 55 dollars for postage.. :O
Re: my hotend can't reach 240° March 09, 2014 10:16PM |
Re: my hotend can't reach 240° March 10, 2014 07:01AM |
