Leds on heatbed - only one lights April 02, 2014 12:13PM |
Re: Leds on heatbed - only one lights April 02, 2014 01:10PM |
Re: Leds on heatbed - only one lights April 02, 2014 01:36PM |
Re: Leds on heatbed - only one lights April 02, 2014 01:47PM |
Re: Leds on heatbed - only one lights April 02, 2014 01:50PM |
Arnold
I would like to see just simply answer
So what is the right work of these leds ? When both light or when one lights. And if one should lights, what is the meaning of second one ? And what is the meaning of leds generally, just that heatbed is powering, no other signal ?
Re: Leds on heatbed - only one lights April 02, 2014 02:11PM |
Re: Leds on heatbed - only one lights April 02, 2014 02:23PM |
tjb1
DaveX
That means you are feeding it DC rather than AC.
There are two leds so one or the other will light, no matter which direction you hook up the power.
What?
Re: Leds on heatbed - only one lights April 02, 2014 02:27PM |
Arnold
Ok, and meaning of led is just that heatbed is powering ?
Re: Leds on heatbed - only one lights April 02, 2014 03:56PM |
A LED is like a check valve. It will only operate with current flowing in one direction. If you hook it up backwards, it won't light up. The idea with the heated beds is that when you (or whoever makes your board) solder the LEDs to the board, they don't know how the board will be wired up. So it's designed so that two LEDs are used, with one of them flipped from the other. This way, regardless of which wire is positive and which is ground, you'll still have an indication that the board is working.Quote
Arnold
Re: Leds on heatbed - only one lights April 02, 2014 05:57PM |
tjb1
DaveX
What?
Re: Leds on heatbed - only one lights April 02, 2014 10:25PM |
ShaneH
tjb1
DaveX
What?
Beat me to it...LOL
If you were able AC power to feed polarity opposed LEDs connected in parallel, from the MOSFET powering the PCB, both would actually light up. For 50% of the AC cycles, each LED is in the correct orientation, and with persistence of vision, would look like they are both lit up. Of course, each one is being alternately turned on/off between 50 and 60 Hz..the leds are being lit up between 25 and 30 times per second, and off for the rest of the cycles per second.
Re: Leds on heatbed - only one lights April 03, 2014 04:14AM |
Each cycle of the AC wave has one positive, and one negative, so you would get 50 or 60 pulses on each, or for the pair 100 or 120 pulses. There's a project that uses audio signals at ~20kHz into some opposite polarity IR LEDs to make an audio to remote-controller adapter: [www.instructables.com]
My apologies -- I didn't intend to suggest that Arnold should run AC through his system, merely that one or the other of the opposite polarity LEDs would shine with DC.
