Openbeam rigidity for larger frames? June 02, 2014 09:18AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Openbeam rigidity for larger frames? June 02, 2014 12:33PM |
Re: Openbeam rigidity for larger frames? June 02, 2014 12:37PM |
Re: Openbeam rigidity for larger frames? June 02, 2014 02:03PM |
Re: Openbeam rigidity for larger frames? June 02, 2014 02:19PM |
Re: Openbeam rigidity for larger frames? June 02, 2014 02:54PM |
Re: Openbeam rigidity for larger frames? June 02, 2014 04:04PM |
MrDoctorDIV
So in an attempt to understand that simply, 1.7X thickness = 2X the length?
Re: Openbeam rigidity for larger frames? June 02, 2014 04:19PM |
OpenBeam's L-shape joining plate is injection molded out of EMS Grivory GVX, a high-performance, high glass fiber reinforced polyamide copolymer that is engineered for metal replacement applications. It has comparible tensile strength to die cast aluminum, at 1/2 the weight.
Re: Openbeam rigidity for larger frames? June 02, 2014 04:21PM |
Yeah, I knew it was relative to current size calculation and not absolute, but good clarifications for others reading.Quote
DaveX
Yes-ish... since the 1.7 factor depends on the doubling of the length. If you quadrupled the length, the thickness would need to be 1.7*1.7, not 1.7*2.
Re: Openbeam rigidity for larger frames? June 03, 2014 07:25AM |
Re: Openbeam rigidity for larger frames? June 11, 2014 12:28PM |
