Nema 17 - stronger motor alternative June 12, 2014 03:17AM |
Re: Nema 17 - stronger motor alternative June 12, 2014 04:24AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Nema 17 - stronger motor alternative June 12, 2014 08:05AM |
Re: Nema 17 - stronger motor alternative June 12, 2014 08:21AM |
Re: Nema 17 - stronger motor alternative June 12, 2014 01:47PM |
Re: Nema 17 - stronger motor alternative June 12, 2014 01:57PM |
Re: Nema 17 - stronger motor alternative June 12, 2014 02:39PM |
Re: Nema 17 - stronger motor alternative June 14, 2014 09:19PM |
Re: Nema 17 - stronger motor alternative June 14, 2014 09:31PM |
I'd like to see a video of your machine running with these drivers to my knowledge nobody's had good luck because of the pulse time and yes I know you can change this but still I have never seen anybody do this very well with these. Please show your machine running and show us how you set up the firmwareQuote
Jim Fong
I use external stepper drivers which can easily be interfaced to the RAMPs step and direction lines. I bought these geckodrives for cheap on eBay. They can handle steppers up to 7amps. High performance drives that can easily spin nema23 motors well over 2000rpm. Overkill but I've been using similar drives on my big cnc and they never miss a beat. Parker compumotor and certain ones from leadshine are also very good drives. Keep on eye on eBay if you are interested in using external drivers with your 3d printer.
Re: Nema 17 - stronger motor alternative June 14, 2014 10:24PM |
Re: Nema 17 - stronger motor alternative June 15, 2014 06:15AM |
Re: Nema 17 - stronger motor alternative June 15, 2014 07:21AM |
jzatopa
The voltage of your power supply has a big effect on stepper performance
Re: Nema 17 - stronger motor alternative June 15, 2014 08:35AM |
cnc dick
With Mach 3 of course every thing works fine that's what it was designed for but you said from the ramps the pulse for step and direction signal is to fast on the ramps this can be changed but I haven't seen anybody have good luck with it. I'm waiting to see how it goes there are ways to change the pulse by putting in delays in it will be interesting to see how it goes like I say to my knowledge nobody's had good luck with this. I have seen people on YouTube bench test ramps and run large stepper drivers but never seen a machine up and running with this set up
Re: Nema 17 - stronger motor alternative June 15, 2014 09:20AM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Nema 17 - stronger motor alternative June 15, 2014 12:00PM |
thejollygrimreaper
I once had an issue with the tb6560 drivers which resulted in a modification to the marlin firmware which allowed the pulse output to be make longer by adding in a very short delay, i have re added the mod to my fork of marlin which also has a few other usefull goodies like hardware pwm capability and certain Mcodes are switched over to buffered
https://github.com/jgrjgr/Marlin currently the step pulse is set to 5us but it's changeable in stepper.cpp at line 243
Re: Nema 17 - stronger motor alternative June 15, 2014 05:53PM |
Re: Nema 17 - stronger motor alternative June 15, 2014 09:08PM |
cnc dick
You said that there has to be many people that use external stepper drivers for 3-D printers I haven't found any if I remember right lobo CNC did on have their first 3-D printer and they have done away with it. If you find any case post a link or pictures video any thing. Anybody that is using external drivers seem to be running Mach 3 for their printer
Re: Nema 17 - stronger motor alternative June 15, 2014 09:46PM |
Re: Nema 17 - stronger motor alternative June 15, 2014 11:52PM |
cnc dick
Okay I'll be waiting to see how yours goes it will be nice if it works good I'm a big fan of the larger stepper drivers it is just to my knowledge other than bench test nobody's had good luck on a actual printer. And yes you can think of that way but the pulse for step and direction that they operate on is very fast compared to standard stepper drivers
Re: Nema 17 - stronger motor alternative June 16, 2014 12:10AM |
Re: Nema 17 - stronger motor alternative June 16, 2014 01:56PM |
Traumflug
jzatopa
Sorry, but in this generalisation it's wrong.
Having a higher voltage doesn't add a single percent of torque at low speeds. The only effect you have, is, you can maintain (constant) torque up to higher RPMs. Wether you ever reach these speeds depends on your motors and you printer gearing.
Re: Nema 17 - stronger motor alternative June 16, 2014 06:01PM |
Re: Nema 17 - stronger motor alternative June 17, 2014 02:53PM |
cnc dick
Re: Nema 17 - stronger motor alternative June 22, 2014 12:58PM |
Re: Nema 17 - stronger motor alternative June 22, 2014 01:38PM |
Re: Nema 17 - stronger motor alternative June 22, 2014 03:02PM |
Arnold
Ok,
so could I use these kind of motors with actual setup for casual reprap with arduino using nema 17:
[www.automationtechnologiesinc.com]
and if yes, what will I need to make it work properly ?
Re: Nema 17 - stronger motor alternative June 22, 2014 04:10PM |
Re: Nema 17 - stronger motor alternative June 22, 2014 05:52PM |
Arnold
I would like to try CNC so that is why I dont want to use nema 17, no moving by belts, but threated rods.
Re: Nema 17 - stronger motor alternative June 23, 2014 02:33PM |
Re: Nema 17 - stronger motor alternative June 23, 2014 05:11PM |
