M41, is anyone using it? June 13, 2014 10:26AM |
Re: M41, is anyone using it? June 13, 2014 10:46AM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: M41, is anyone using it? June 13, 2014 10:47AM |
Re: M41, is anyone using it? June 13, 2014 10:53AM |
Re: M41, is anyone using it? June 13, 2014 12:09PM |
Re: M41, is anyone using it? June 13, 2014 12:13PM |
Re: M41, is anyone using it? June 13, 2014 01:02PM |
M23 filea.gcode M24
Re: M41, is anyone using it? June 13, 2014 06:51PM |
Re: M41, is anyone using it? June 13, 2014 07:00PM |
Re: M41, is anyone using it? June 13, 2014 09:00PM |
thejollygrimreaper
there's another m code which combines to two M32 that one might be worth a try , otherwise some modifications might be in order
Re: M41, is anyone using it? June 13, 2014 09:32PM |
crispy1
thejollygrimreaper
I can't find that one documented on the gcode page ( [reprap.org] ), do you have a link to documentation?
Re: M41, is anyone using it? June 13, 2014 09:37PM |
Re: M41, is anyone using it? June 13, 2014 11:07PM |
Re: M41, is anyone using it? June 13, 2014 11:25PM |
A2
Caution noob questions ahead
Interesting option, curious if the title could be a little more explanatory for the noob?
M32: Automatically executes a gcode file from a SD card
[reprap.org]
Q: Say you had a conveyor belt on your build plate, and you had 60 unique parts that you wanted printed. Could you add 60 unique M32 gcode commands (file paths)? Could M32 be nested in a loop with a counter or some thing to find the next file path, or does the counter get lost at the end of a print?
Re: M41, is anyone using it? June 14, 2014 02:23PM |
thejollygrimreaper
i found it in the marlin code
specifically line 1731 in the Marlin_main.cpp
i think there are probably a few functions in the marlin firmware that aren't listed in the wiki , it would probably be best to use [github.com] as a moreup to date reference for available gcodes
