one driver must go down sad smiley help
Posted by amira
June 23, 2014 05:53PM
i have this problem with drivers
at first my printer work couple times
and
suddenly one of the drivers gets hot (the extruder driver ) when i connect it and does not work
i get another one and tried again
the same happened to X axis driver i take it out
and put it alone without the other driver
still gets hot
i tried the 3 other driver they work
why this happened when they are 4 ?
Re: one driver must go down sad smiley help
June 23, 2014 05:59PM
Hi, posting the same topic in three subforums is not wanted ( [forums.reprap.org] )
I suggest you first try to compose a better question and then not put a copy in three different subfora.
One question, do you have cooling elements on your drivers, and do you have a cooling fan pointed at those cooling elements?
http://www.marinusdebeer.nl/
June 23, 2014 06:09PM
I did not know in which section should i post it
yes i have
they are all cold except one must get hot
June 23, 2014 06:16PM
we made a printer before and it was working
and this is the second one and also was working
suddenly this happened :\
