plywood bed August 03, 2014 04:00PM |
Re: plywood bed August 04, 2014 05:41AM |
Re: plywood bed August 04, 2014 07:51AM |
So I presume that since you tried it out and it worked for you that you added it to the list? No? Well why not? There's your answer.Quote
Gersen
Looking at the results I ask myself why this solution is not in the list of reprap possible bed.
Re: plywood bed August 04, 2014 02:57PM |
cdru
My guess is that it's not on the list as the results are not highly repeatable. Every time you scrape off a print you're going to be changing the surface, much more so then a metal, acrylic, or glass bed. Other issues are easily gouged, inability to use a heated bed, surface finish, tearing off wood fibers, weight, flatness, dimensional stabality...The only thing it has going for it is that it's cheap.
Re: plywood bed August 14, 2014 09:43PM |
Re: plywood bed August 15, 2014 08:53AM |
Re: plywood bed August 15, 2014 08:47PM |
Re: plywood bed August 18, 2014 07:26AM |
Gersen
I think someone already try this. However I'd like to post my experience.
After trying different solution for the bed I try to print directly on plywood with very good results: good adesion and easy to remove with a sharp knife.
I'm using a 12 mm multi-layer that is manufactured with very good surface finish. Forthermore is a very cheap material.
Re: plywood bed August 18, 2014 09:08AM |
