Hi everyone,
I've started designing a new printer, and though it is mostly just for fun I thought I would see if anyone is particularly interested. It goes in the opposite direction of most RepRaps I've seen and for good reason- It won't be terribly practical for too many people.
A little background- I am a mechanical engineer who does automation engineering, and I find the difference between here and the industrial world so interesting. We in the RepRap community do everything to save every dollar, and the difference between $10 and $50 is huge here, while there if something very minor costs a few hundred dollars extra, it isn't a big deal at all. I've built machines with a tenth the functionality and purpose of a reprap for many thousands of dollars, simply because it had to adhere to codes and last 20 years.
I have to add that the developers here have done an
astounding job at keeping costs down while building an amazing machine. The longer I work in my field the more respect I gain for people like nophead and Prusa- they are truly amazing.
But what if I have the money for a Makerbot but want to do it myself? I would still like to stay in the ballpark of several hundred dollars, but with a couple hundred more than my $400 i3 I would like to build a printer that is more solid, easy on the eye, and will need a lot less maintenance over time. I also want to include many features not standard on most repraps or 3D printers in general. Though none of this is truly necessary, I have plenty of time, money, and space, but wouldn't buy a commercial printer. Here's what I'm looking at:
-Solid construction with no limitations on size and weight (to a degree of course)
-Clear heated enclosure or semi-enclosure
-Fume dispersment/filtering.
-All visible 3d-printed parts vapor treated if possible
-Enclosed, actively cooled electronics with relays powering everything. No current above signal level through ramps besides motors.
-No exposed wiring/motors
-High cooling abilities at the print head, from a frame mounted fan
-Automatic bed leveling
-AC powered bed, <30s time to 100C and 12"x12" (300mm)
-Bluetooth printing
-Built in Acetone vapor treating. It will have an out-of-view acetone "tank" and use custom pronterface buttons or an external interface to treat parts either as they lie on the bed after printing or manually later.
-Fire safety. I want to be able to start a print and go to work or to sleep, but wouldn't do that without some kind of automatic shutoff and
preferably an integrated fire suppression system. Being a single enclosed unit I imagine a few small co2 canisters could fill it pretty quickly and put out any potential fires, but I will need to look into this more.
I either have implemented the above or have the ability to, but here are some more far-fetched ideas that won't make the cut without some extra help:
-Servos or linear motors instead of steppers. While steppers work, there is a reason they are very rarely used commercially and servos would be very nice.
-Wireless internet connection for remote monitoring- I'd like a text when my print is done. The new makerbot mobile interface seems mostly gimmicky, but a simple notification would be nice.
If you're interested, let me know what you think.
