3 Extruders 1 Hotend Colour mixing August 20, 2014 08:36AM |
Re: 3 Extruders 1 Hotend Colour mixing August 21, 2014 07:10AM |
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 08:07AM |
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 01:49PM |
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 01:59PM |
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 02:15PM |
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 02:22PM |
dave3d
Wow. This has got to be the way forward. So light and compact.
Questions:
- are there no PTFE liners in the tubes?
- I assume you are using 1.75mm filament, are the stainless tubes 2mm id?
- are the tubes a press fit in the hot end?
- I can't see what the central tube does. You are using 3 colours, right? Looks like 2 stage heating element. Is it soldered to the brass fittings on the other tubes or just heated by contact?
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 02:23PM |
Feign
This thing is absolutely brilliant by the way, I love it and would like to see more.
Re: 3 Extruders 1 Hotend Colour mixing September 02, 2014 06:04PM |
Re: 3 Extruders 1 Hotend Colour mixing September 03, 2014 02:36AM |
dave3d
Thanks Xabbax. I visited your website.
I like the welding nozzles idea. Couple of further questions:-
- what is the centre hole in the heating block for?
- is the water cooling by natural convection or forced circulation with a pump? If so what kind have you used?
I would like to build one. I have tried twin nozzles with a Bowden setup on my OrdBot. The problem was getting them level. Your nozzle would eliminate that.
Re: 3 Extruders 1 Hotend Colour mixing September 03, 2014 06:55AM |
Re: 3 Extruders 1 Hotend Colour mixing September 03, 2014 07:55AM |
dave3d
Thanks Xabbax. Yes, can you post the OpenScad code. That would be useful.
The tubes look to be at about 45 deg. Is that right?
Re: 3 Extruders 1 Hotend Colour mixing September 03, 2014 01:02PM |
Re: 3 Extruders 1 Hotend Colour mixing October 15, 2014 01:37PM |
Re: 3 Extruders 1 Hotend Colour mixing October 15, 2014 02:41PM |
