Too many plugs, not enough pins
August 29, 2014 07:06AM
Hi all
I am a newbie to this (so excuse my ignorance), here is my predicament.
I have a Prusa Mendel i2 with a Melzi V2 ramps board. I have just received my smart controller, but cannot figure how to plug it in. (see photos).
Any help with this issue would be greatly appreciated
Thanks
open | download - P8292079.JPG (218.5 KB)
open | download - P8292081.JPG (162.1 KB)
Re: Too many plugs, not enough pins
August 29, 2014 07:17AM
That's a RAMPs adapter. You need this one -
or you can look at where the pins go and create your own solution.
August 29, 2014 07:22AM
Look's like this may be it - [www.geeetech.com]
You should check the Melzi pinout at this location and compare it to the pinout of the Sanguinololu board to verify that it is the same.
August 29, 2014 07:23AM
Thanks TJB.
What is that called, (and where do I get it)?
thumbs up
August 29, 2014 07:33AM
Got it... Many Thanks...hot smiley
September 21, 2014 08:08AM
Is this supposed to be plug and play?
As far as I can tell the pinout on the Melzi is the same as the Sanguinololu board.
However when I plug the smart controller in (via the adapter), all I get is... nothing.
Any help with this issue would be greatly appreciated.
September 21, 2014 05:55PM
You'll probably have to reconfigure your firmware to support the controller. I've not done this myself but the relevant section of configuration.h looks pretty self explanatory.
September 21, 2014 10:07PM
Thanks for that... how do I find the location of the firmware on my computer?
thumbs up
September 22, 2014 05:50PM
Your supplier may provide a pre-configured firmware in which case you just need download it, tweak configuration.h to suit the LCD controller, and upload it. If not, you'll have to download the firmware from github and configure it from scratch.
September 24, 2014 12:14PM
Hi I have a melzi too and when I got lcd they gave me guide to install ,mines a panolo thing so not the exact same as yours but will guide you in the right direction winking smiley
open | download - Panelolu2_Melzi_HOWTO_draft.pdf (56.1 KB)
open | download - 20140911_173516.jpg (583.7 KB)
September 24, 2014 05:52PM
Fantastic!! thanks Sloppyprinter.
that is a great help.
(hopefully will solve my woes.)
smiling bouncing smiley
September 25, 2014 12:03PM
buildit
Ya Welcome fella let me know if ya get it sorted. winking smiley
