my guess is either a short in the heater of which you can check its resistance, and a possibility that 350watts (of which half the power is 12v and likely the other half 5v) may not have enough power to work properly especially so if you are using a heated cartridge, or a 2 resistor setup.
check the heater wiring, and also verify the current rating for 12v. labels should be on the side of the supply, also provide the supply model number, believe it or not '350 Watt Thermaltake ATX 12V Power Supply' is not specific enough.
Edited 1 time(s). Last edit at 09/01/2014 01:59PM by jamesdanielv.
