Swollen Calibration Cube September 11, 2014 10:12PM |
Re: Swollen Calibration Cube September 12, 2014 12:11PM |
Re: Swollen Calibration Cube September 12, 2014 08:32PM |
Re: Swollen Calibration Cube September 12, 2014 08:45PM |
Re: Swollen Calibration Cube September 12, 2014 11:32PM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: Swollen Calibration Cube September 12, 2014 11:58PM |
Re: Swollen Calibration Cube September 13, 2014 01:57AM |
Re: Swollen Calibration Cube September 13, 2014 04:46AM |
brucehvn
If one of the z motors is stuttering, then that usually points to the stepper driver voltage settings not being high enough. Also, you need to make sure the z threaded rods are not binding in any way. When I first put together my i3, the threads in the m5 rod had some gunk in them and it would cause similar behavior when it would hit the gunk. I ended up having to run an m5 nut up and down the whole rod to clean it all out, then some 3 in 1 oil and they work good now. You should also disconnect the threaded rods totally and make sure the x-axis moves smoothly up and down when you raise and lower it manually.
Re: Swollen Calibration Cube September 13, 2014 11:19AM |
Re: Swollen Calibration Cube September 13, 2014 11:25AM |
Re: Swollen Calibration Cube September 13, 2014 02:29PM |
