Nema 17 - set up speed in Sprinter
September 21, 2014 05:04AM
Hello everyone,
I would like to ask for a little advice how to set up speed for nema 17 in Sprinter. I use M8 rods and would like to force to spin these motors faster. If I set up AXIS STEP PER UNIT I just control how many spins per mm motor should spin compared with rod I use ?
But what If I want change rotation speed ? For example I have now 1mm per two seconds and I want 1mm per 1s.
Re: Nema 17 - set up speed in Sprinter
September 21, 2014 05:27AM
yes step /mm sets just that, how many steps is required to move 1 mm.
you want feed rate, controlled by your slicer when producing gcode and the max feed rate in your firmware
Or by your GUI in manual mode.
if you look at raw gcode
eg G1 Z10 F300
move to z 10 at 300 mm/min (5 mm/sec) (or up the the max feed rate in your firmware)
so 1mm/sec would be G1 Z10 F60
Edited 2 time(s). Last edit at 09/21/2014 05:31AM by Dust.
September 21, 2014 05:34AM
Thank you Dust for information, now I know where I should focus. Thx
September 21, 2014 06:57AM
One more question, what is the maximum feedrate I can set in arduino for nema 17 ? Now its set to ( define _MAX_FEEDRATE {400, 400, 2, 45}.) So what is the usable maximum number when motors spin correctly?
September 21, 2014 07:45AM
That depends on your hardware and stepper power
Imposable to say remotely. and best determined by experimentation
Basically set the numbers high in firmware then set them low in your GUI, and try a manual move.. if it moves ok increase the rate in your GUI, till you find the rate at which it breaks. Put your highest working value back into your firmware.
Each axis will probably be different.
NB be careful. some GUI's use mm/second other mm/min and the firmware is similar parts are in mm/sec and other parts in mm/min
Edited 1 time(s). Last edit at 09/21/2014 07:55AM by Dust.
September 21, 2014 08:01AM
Ok, is it possible somehow damage hardware or motors itself if these numbers are high ? What is the sign that speed is for motor too high ?
September 21, 2014 06:45PM
no you cant damage the motors like this.
The motors will buzz, but not rotate.
September 22, 2014 01:22AM
Thanks Dust,
I have made some test with feedrate and it works pretty well. Thanks
