Drilling nozzle hole October 19, 2014 10:45PM |
Anonymous User
Re: Drilling nozzle hole October 19, 2014 11:02PM |
Re: Drilling nozzle hole October 19, 2014 11:58PM |
Re: Drilling nozzle hole October 20, 2014 02:15AM |
Re: Drilling nozzle hole October 20, 2014 02:35AM |
Admin Registered: 13 years ago Posts: 730 |
Re: Drilling nozzle hole October 20, 2014 09:02AM |
While it might work at 3000 RPM, I bet you'll go through quite a few broken bits at that speed. For extremely small diameter bits ideally your speed is much much higher, as in an order of magnitude higher. They'll work better at 25k and higher. Taking things to an absurd level, the bits that get used for microvias in PCB manufacturing can be as small as 75µm (.075mm) with a spindle speed of 375k rpm in order to get to the recommended SFM (surface feet per minute) for the material and bit.Quote
Robert_Paulson
All I can say is you need about 3000 rpm on your spindle, a magnifying glass, and the Zen state of the Dalai Lama.
Anonymous User
Re: Drilling nozzle hole October 20, 2014 09:37AM |
Re: Drilling nozzle hole October 20, 2014 03:37PM |
cdru
Re: Drilling nozzle hole October 20, 2014 04:06PM |
Anonymous User
Re: Drilling nozzle hole October 20, 2014 08:15PM |
Re: Drilling nozzle hole October 20, 2014 08:22PM |
Have Blue
Watchmakers would create a tiny divot on the center of the stock with a graver, and then use a micro drill bit held in a pin vise. All by hand, no tailstock! I saw a video of this technique on youtube long ago but unfortunately cannot find it...
nophead
The technique with a graver is called "catching the centre". I had a link to an excellent video on my blog, but for some reason the video has become private. Here is another one though:
[www.youtube.com]
Anonymous User
Re: Drilling nozzle hole October 20, 2014 08:44PM |
Re: Drilling nozzle hole October 20, 2014 09:08PM |
Re: Drilling nozzle hole October 20, 2014 09:29PM |
Anonymous User
Re: Drilling nozzle hole October 20, 2014 09:57PM |
Re: Drilling nozzle hole October 21, 2014 10:16AM |
In those videos (link again for reference), I do not think the guy is actually making a nozzle for a hot end. I think he is just demonstrating the technique.Quote
Robert_Paulson
You kind of lost me on the 4th video? When he put the drill bit through the nozzle and spun it around the bit. Seems like an over sized hole.
Certainly possible. In the acorn nut video it looks like he doesn't use a center or a graver. They make it look easy in the videos, but as GITRDUN pointed out it sounds like it is harder than it looks.Quote
Robert_Paulson
But I think having the countersunk tip will degrade print quality.
Re: Drilling nozzle hole October 22, 2014 02:25AM |
