G-Code and Arduino (2) October 22, 2014 09:43AM |
Re: G-Code and Arduino (2) October 22, 2014 10:35AM |
Re: G-Code and Arduino (2) October 22, 2014 10:47AM |
Re: G-Code and Arduino (2) October 22, 2014 10:49AM |
Re: G-Code and Arduino (2) October 22, 2014 10:55AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: G-Code and Arduino (2) October 22, 2014 12:48PM |
This is not a straight forward thing since the actual positioning depends a lot on the hardware, possible accelerations and many other factors.Quote
waseem salem el-mofty
thank you, do you know as a (1,2,3,...) the steps from a G-Code command -> to moving the extruder to the specific (x,y,z) location through the arduino board (G-Code cmmand->Output from the arduino that makes the x,y,z with the specific value)?
Re: G-Code and Arduino (2) October 22, 2014 01:33PM |
Srek
Is there a specific goal you want to achieve? Maybe it is easier to help you if we know what you are after
Re: G-Code and Arduino (2) October 22, 2014 02:40PM |
Re: G-Code and Arduino (2) October 22, 2014 02:59PM |
I want to learn what is the way (Command story =D ) from the G-Code to the Arduino pins, how the arduino understands the G-Code command and translate it into a movement (motor stepping).....
Re: G-Code and Arduino (2) October 22, 2014 03:04PM |
Re: G-Code and Arduino (2) October 22, 2014 04:21PM |
Admin Registered: 16 years ago Posts: 13,890 |
