Why do SLA printers pull each layer? October 24, 2014 10:28AM |
Re: Why do SLA printers pull each layer? October 24, 2014 10:35AM |
Re: Why do SLA printers pull each layer? October 24, 2014 09:10PM |
Re: Why do SLA printers pull each layer? October 26, 2014 06:32PM |
Thought it was clear I knew what frames were by talking about them. I guess not. To be more clear, because the object is moving constantly you could play on the frame rate by increasing it rather than only using a frame per cleanly moveable distance. Of course you still run into the motor's capability of moving certain distances at a time at whatever stepping resolution you have.Quote
MrDoctorDIV
Get a good enough frame rate and a clean enough setup and you could essentially remove visibility of layers on curves and shallow slopes, right?
Re: Why do SLA printers pull each layer? October 26, 2014 06:46PM |
Re: Why do SLA printers pull each layer? October 27, 2014 03:35AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Why do SLA printers pull each layer? December 20, 2014 06:11PM |
Re: Why do SLA printers pull each layer? December 21, 2014 08:19PM |
Re: Why do SLA printers pull each layer? March 18, 2015 06:52PM |
With all of the benefits I had mentioned.Quote
MrDoctorDIV
...a continuous pull would speed up the print...essentially remove visibility of layers on curves and shallow slopes, right?
Re: Why do SLA printers pull each layer? March 19, 2015 06:29AM |
Re: Why do SLA printers pull each layer? March 19, 2015 08:12PM |
Re: Why do SLA printers pull each layer? March 20, 2015 01:27PM |
