Problems in Printer Interface
Posted by herisuprapto
October 29, 2014 12:58AM
I really need help to fix Printer Interface at the rightmost window and do not know the beginning of my problems.
This occurs when pressing the Connect button, then on the far right window appears similar to the letters y in some parts, as shown in number 1.
Then at number 2, like the first, this happens every time checking Monitors Printers and pressing the Check Temp, the letters grow continuously. Also a graph showing temperature and hotend heatbed not work.
At number 3, it is different in the Command Prompt window, a window which always coincided with Printer Interface window and there everything looks fine.
I've tried to start over all the installation dependencies and using new Printer Interface, but the result is the same and so expect help from you guys to help me, thank you very much.
Regards,
Heri
