Instead of connecting the BT module to the serial port 0 with super fine soldering and a great possibility to fry that board like described here:
reprap.org]
I did connect the BT module to serial port 1 on the EXT connector (5V, Gnd, Rx1, Tx1) and i did change the firmware to listen on this port.
Changes are in MarlinSerial.h und MarlinSerial.cpp. Attached patch is for nophead fork. Do a "#define SERIALPORT 1" in config.h to swap to serial port 1.
imgur.com]
