Kossel Mini Kit Review December 16, 2014 03:57AM |
Re: Kossel Mini Kit Review December 16, 2014 07:58AM |
The problem with using the hot end nozzle as the probe is if there is any plastic on the tip, it won't measure tripped. It will just continue driving the hotend down into the bed. This is I'm guessing what caused your hot end to become crooked. This is also the voice of experience talking since I had the same idea...and ran into the same issue.Quote
Bogofoo
The kit is set up for 3mm filament with a built-in z probe that uses the hotend nozzle itself as the probe. While this is an interesting idea, it allows some slop in the hotend alignment and I had a crooked hotend after I ran the G29 leveling procedure. I would much prefer a manual release z-probe to something that adds a degree of freedom to the hotend.
Re: Kossel Mini Kit Review December 16, 2014 10:42AM |
Re: Kossel Mini Kit Review December 22, 2014 09:23AM |
Re: Kossel Mini Kit Review December 22, 2014 10:12AM |
Re: Kossel Mini Kit Review December 23, 2014 11:22AM |
tjb1
I've been running my Kossel Mini using the hotend as a bed probe with FSR to detect hits. It is running Marlin with upgrades by Johann and the threshold on the sensors is set so that the lightest touch triggers and it grabs the baseline right before the probing starts so it works very well. If you got a crooked hotend I think you may have other issues, I've had some configuration errors and while playing around have slammed the hotend into the bed many times and never have had the hotend come loose or change position.
Re: Kossel Mini Kit Review December 23, 2014 02:41PM |
Re: Kossel Mini Kit Review December 27, 2014 12:06AM |
