Belt Drive Extruder 00str00der dead? December 16, 2014 03:44PM |
Re: Belt Drive Extruder 00str00der dead? December 16, 2014 04:03PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Belt Drive Extruder 00str00der dead? December 16, 2014 04:20PM |
Re: Belt Drive Extruder 00str00der dead? December 16, 2014 06:07PM |
Re: Belt Drive Extruder 00str00der dead? December 16, 2014 06:26PM |
jamesdanielv
in reality you will need spring tension as filament shape may stress to a different shape such as oval, and it can happen even during load and retraction. you may be better off with a knurled tool end, but I'm not sure entirely on how you would be applying pressure to it. the belt extruder idea. what benefits does it have with it other that less backlash?
Re: Belt Drive Extruder 00str00der dead? December 16, 2014 06:53PM |
Re: Belt Drive Extruder 00str00der dead? December 16, 2014 07:01PM |
Admin Registered: 12 years ago Posts: 1,063 |
jaguarking11
jamesdanielv
Spring tension I find is not required. The reason is simple, the tolerances of filament even cheap stuff is within spec, it wont oval the filament unless its either severely over spec or the idler bearing is over-tightened.
Belt drive has the advantage of using proper off the shelf machined parts if you can get them and you design around the parts strength. You can have a more precise extruder that way. Belts are also very quiet in operation as well as long lived. Servicing should be simple if designed correctly.
Re: Belt Drive Extruder 00str00der dead? December 17, 2014 12:59AM |
