Purely for science I tested out some IGUS 8mm linear plane bearings. Here's a
little video of the normal LM8UU's and IGUS ones to compare the noise they make.
Other interesting differences:
Cost: Fing expensive. I think these were about £8 each, for which you can get a dozen LM8UU bearings.
Size: Annoyingly they are exactly 1mm longer and 1mm wider than the LM8UU. Quite infuriating because I had to reprint my x carriage with wider gaps.
Performance: Very smooth, but x carriage is still quite noisy at certain speeds. This suggests the noise issues are caused by resonance in the structure, and sure enough, applying dampening on the parallel rails (i3) mitigates some of the noise. They are quieter generally though in most cases.
