Building Another Printer - Which route should I take January 22, 2015 09:45PM |
Re: Building Another Printer - Which route should I take January 23, 2015 02:25AM |
Re: Building Another Printer - Which route should I take January 23, 2015 05:41AM |
Re: Building Another Printer - Which route should I take January 23, 2015 10:43AM |
Re: Building Another Printer - Which route should I take January 23, 2015 11:02AM |
Re: Building Another Printer - Which route should I take January 23, 2015 01:08PM |
Re: Building Another Printer - Which route should I take January 23, 2015 01:38PM |
Re: Building Another Printer - Which route should I take January 23, 2015 03:25PM |
runninfarmer
I'll echo the comments made by Zavashier. It's hard to use a Delta printer as a production printer, IMO, though I'm sure it's being done. Deltas are fun to watch but there's constant wear on all linear motion components. That was the first type of printer I built, and that was a bad idea. Insanely hard to calibrate without autoleveling for a beginner. The stepper noise I had with my Delta was also intense. I'm a big fan of the CoreXY and I'm currently designing/building a large volume one. I've found that CoreXY is much quieter and it's great to capture Delta type speeds with cartesian precision.
Re: Building Another Printer - Which route should I take January 23, 2015 04:35PM |
Re: Building Another Printer - Which route should I take January 23, 2015 05:14PM |
Re: Building Another Printer - Which route should I take January 23, 2015 05:20PM |
Re: Building Another Printer - Which route should I take January 24, 2015 07:13PM |
Re: Building Another Printer - Which route should I take January 24, 2015 07:38PM |
Re: Building Another Printer - Which route should I take January 25, 2015 10:51AM |
Re: Building Another Printer - Which route should I take January 27, 2015 12:06AM |
Re: Building Another Printer - Which route should I take January 28, 2015 01:01AM |
Re: Building Another Printer - Which route should I take January 28, 2015 10:15AM |
Re: Building Another Printer - Which route should I take January 28, 2015 01:01PM |
The reduction of resolution is an easy problem to solve. Just use the lowest resolution as the baseline...away from the center lobes your always increasing resolution!Quote
dc42
People also complain about the reduction in precision of a delta near the centre of the bed; but all that matters is that you get at least the precision you need. Who needs 0.012mm precision, when the extrusion width is 0.3mm or more?
Re: Building Another Printer - Which route should I take January 28, 2015 03:06PM |
Are you sure ? Reprap is not fixed into 3D printing. A machine able to replicate itself could be a CNC mill. See first page of reprap.orgQuote
jaguarking11
I know this goes against the reprap mission
Re: Building Another Printer - Which route should I take March 16, 2015 11:02AM |
Re: Building Another Printer - Which route should I take March 18, 2015 10:02PM |
Re: Building Another Printer - Which route should I take March 19, 2015 09:25PM |
J.A.C.
I have the same interest as you Redhatman,
I am looking forward to see the evolution ^_^
Re: Building Another Printer - Which route should I take March 19, 2015 10:10PM |
Re: Building Another Printer - Which route should I take March 19, 2015 10:26PM |
J.A.C.
Are the "Cube" structure hold by printed plastic parts? if so, at lest add 8 metal brackets to hold them and remove any future stress for the structure.
Re: Building Another Printer - Which route should I take April 20, 2015 10:35AM |
Re: Building Another Printer - Which route should I take April 20, 2015 10:51AM |
Re: Building Another Printer - Which route should I take April 20, 2015 05:23PM |
