rndm Wrote:
> I agree that self replication is key. But
> microfactories are the more promising route to
> self-replication. Why bother figuring out how to
Darwin hardly qualifies as self-replicating, some people just love to blindly assign labels to make themselves feel great. And guess what, you SHOULDN'T build the bars etc, you can buy them too cheaply to matter vs what it takes to actually self replicate. But Darwin already suffers from having decided to lock stuff in that simply doesn't deserve to be locked in at this point of a design. For that matter, no point of any good design should EVER be locked in. If you see a point of substantial improvement for little extra cost or effort, you IMPROVE it. If you don't, you cripple yourself, might as well cut off your right hand and 3 fingers on your left too while you're crippling yourself..
At any rate I'm on it now. I actually do things, not throw up my hands and say it can't be done or you have to use special tools or CNC or woodworking. I already have a machine that doesn't, shouldn't be hard to catch that part. I bet you'd say you can't light salt water on fire either. Guess what? As of recently you're wrong on that too..
news.yahoo.com]
And take note! It was POSSIBLE before. Anyone who said it wasn't since there's been RF generators was WRONG, PERIOD, end of discussion. They were stating something that THEY DIDN'T KNOW, greatly over extending their actual knowledge, because they thought it wasn't, and somehow decided it wasn't, even though they obviously didn't know that for an actually correct fact. Sort of like saying it takes CNC or major tools to make a decent CNC. Just because you don't know how and I haven't told you yet doesn't mean you actually know something factual about whether or not it's possible or exactly what is or isn't required. I do.
I've had my CNC running since 2001 or earlier. I've done it, it's old news, it was easy. I don't need anyone's approval, I don't have to stick it on the net and explain every little detail for me to know it's real..
I know those who say it can't be done just haven't tried much, and don't know how to attack a problem correctly. Been there done that, only took a month or two of off and on tinkering around and working past the issues.
Cut and past of the other message I started typing below. Not really going to finish it out, little need. Still some points some of you could use.. I especially like the name for my machine now..
The Impossible CNC: The Can't Machine!
It can't be any good!
It can't work!
You can't go to Lowe's and buy all the parts!
You can't assemble it in an evening or two!
It can't be all metal where it counts!
It can't not even need a CNC or wood working tools!
Ok, from reading the posts you're one of the few on here with some good clue re engineering vs some actual real world production experience, so I like you already. But if you think I've missed the point, then you're missing mine. For an initial phase of such a project, some of the initial aiming points seem to be a bit off..
Ah well, not even going to finish the rest of this post below really. BTW I can type fast if you guys didn't already know, easy enough for me to take a minute and go into details.. Suffice it to say your post reads a little humorously to me, saying how much something can't be done that I have sitting behind me.
It's easy to throw up your hands and say something can't be done. In a lot of cases, all it really takes is a little work. Most people have the attention span and creativity of a gnat. If the first way you think of doesn't work, you don't stick with it and throw up your hands and say you need a CNC, you get your ass back to Lowes and find other parts that will work, or look at other parts to find a different way to do it. You don't just pronounce something impossible when you really are just lazy and have no idea if it could be done, that's extremely poor science and engineering. Guess what, LOOK at the high quality rails from Lowes. They're 90% of what you need for a metal CNC machine ALREADY, without doing anything else. Look at all the other parts at Lowes. Of COURSE there's a way to find and use parts there to lash those rails together, and make an all metal CNC with almost no work. It was a no brainer to me before I even started the build. Took about a month to get one together, to find the right parts and ways to get it together. Wasn't even particularly hard to do, much less impossible. Just took putting in the time and not copping out with 'it's impossible, you need tools/cnc/whatever'.
The people who say it can't be done haven't tried everything. In fact usually they haven't even tried that much of anything on the particular point in question. If your first thought or two for a particular solution doesn't pan out you try a few dozen others. You don't just say 'it can't be done' without having really tried much of anything..
Remember, not everything is on the net.
nophead Wrote:
> I think Alan69's and rndm,s posts completely miss
> the point of the project.
> Self replication is not a gimmick it is key. Given
> a set of FDM parts made by another machine and
> some cheap off the shelf rods and fasteners,
> anybody who can follow a sequence of written
> instructions can build a Darwin without having to
> do accurate cutting and drilling. The cost to
> build it yourself is as low as it could be, just
> the price of the raw plastic plus other off the
> shelf parts like screws which are volume mass
> produced at low cost.
Great! Send me and everyone else all these super low cost parts right now! ??
You don't worry about building the best putter in the world, one that never misses from 6 feet out, when you're still standing on the tee and need a driver first not a putter. Pretty much anything moderate CNC can basically self replicate or close, there isn't anything super special about it. Santa and the Tooth Fairy aren't going to come by and bestow magical powers on it, it's still just a CNC extruder, not the slightest in superior to basically any other ok CNC with an extruder head.
Most CNCs sit unused 95% of the time or more. Where's the advantage of using 298's and high powered steppers in a machine that really doesn't matter if it finishes the part in 3 minutes or 5? Spec'd with $200 worth of motor is fine when you need it, simply over-engineered when not. Where's the advantage in separate intelligent controllers, and having to network them together? Who's built a 20' cube Darwin and might really need this? I guarantee you if I hide the boards from you, you'll never tell whether it was being run with 3 separate networked controllers, or a single controller with 3 axes of control. Guess which takes 3 boards instead of one and will end up being 2+ times more expensive, with extra stuff to build?
> If you don't have a machine that can make a set of
> parts then it makes no sense to make a Darwin by
> hand.
Sorry, Darwin is nothing but a CNC. There isn't anything super special about it's particular design, you're making a distinction that isn't relevant. CNC with an extruder head. If you use a full CNC like a Bridgeport to build another, it's just as much a self replicator as Darwin. The general design was around long before Darwin, there is nothing magic about it vs any other.
> Simple conventional CNC Designs like the
> McWire machine Zach is running with are much
> easier to make but you do need accurate drilling
> and cutting.
You need to study how I do things and pick up some tricks. Extruded aluminum rail is already engineered. Rolled steel rails are already engineered. Manufactured 1/4" nuts are already precise. Put two nuts under the rolling rail to get an accurate offset and drill two holes through both. Doesn't matter exactly where those holes are. Doesn't need a PDF form. You self reference already engineered accuracy, and you obtain end accuracy only where it's actually needed and useful. Building in things that have to be critically accurate that don't actually need that critical accuracy is not a sound engineering philosophy. That's how you end up with $900 toilet seats, or expensive steppers when really Darwin could run with about any $5 or $10 surplus motors, there's nothing particularly demanding about it. Fine if you're doing production, THEN add that in when and for those needing it. But engineering it into a basic machine when 95% of them won't even come close to really using it is not cost effective. Simple waste of that nature is the ABSOLUTE enemy of anything good. The general idea behind Darwin will be severely compromised because of it. For sure even if Darwin is great, the first person to copy Darwin and adapt it with more practical motors will take over. The people who love to quote specs and say only what they say is perfect will do will be quoting to an empty room. Being able to say "My Darwin clone is $185 less and you won't even notice the difference!" will beat you to heck and back every time.
> There is more to drilling an accurate
> hole than using a PDF template. It's a good
> starting point but you need to center punch, pilot
> drill, counter sink and de-burr. You need a drill
> press and a set of sharp drills. You need to know
> what speed to drill. I.e. you need metal work
> skills and a set of metalwork tools. The tools
> will set you back a few hundred dollars, of the
> same order as the price of the complete machine.
None of the above. Go to Lowes. Buy about $75-100 of the right parts. Use a hand drill, saw or dremel, and screwdriver etc to build. Align accurately once it's together. Did it myself. No complex tools. No woodworking and needing extraneous tools to make. Relying on already manufactured parts to obtain high accuracy.
At one time there WERE no CNC tools. There weren't even any machine tools. The first guy to build something accurate didn't throw up his hands and say "I don't have a super accurate tool to work with, I can't do anything!" You use the accuracy you CAN achieve and good design practices to obtain high accuracy, beyond the accuracy of the parts themselves. If you think that's not possible, think harder and realize there wouldn't be anything accurately small if you couldn't obtain it from something larger and less accurate.
> You can avoid the need for tools and skill by
> getting the parts cut by CNC but then you might as
> well build the Fab@Home machine which is already
> designed to be made by CNC. It does cost a few
> $1000 to get the parts made though.
Or just be cheap and use my methods..
> have the capital. Darwin is only a prototype, it
> does not make sense to mass produce a prototype.
Doesn't make sense to make it have unnecessarily tight tolerances on parts that shouldn't matter for lack of 30 minutes of programming either.
> All these alternatives can't self Replicate so
> they are always more expensive or require more
> skill to make than a Darwin and they can't
> evolve.
Huge erroneous assumption here. How much is an extruder kit? $90. About how much are relatively equivalent parts from Lowes? About $30. Savings of $60 for every single person wanting to build one, for the cost of doing a little up front re-engineering to rely on inexpensive found parts and accuracy. Way worth a little time investment and save everyone $50 or more..
All up cost of making a RAP machine from Lowes parts should be around $300. That's CNC, extruder, controller, good surplus steppers. You guys have inspired me, since most of a machine is sitting behind me at about $150, all I need to do is hack an extruder head.
I think I'll call it Alan's SuperCheapSuperEffectiveRAP. You'll be able to go get the parts at Lowes, and have it together in no time with no special tools, or waiting on someone to send you stuff or find someone already with a Darwin. If you want, you can even print out and build the parts for a Darwin, and use it to build one up. I imagine most will get about 1/4 of the way into printing a Darwin with it and say, "Hmm, wow, if this is already making great parts, why was I building a Darwin again? Just for the stunt to say it could replicate itself? Hmm.."
Parts aren't going to know what machine they came off of, the Darwin made parts won't be any more special than made with anything else. The 'REP' part of REPRAP is actually the least useful part of it, and will continue to be relatively so well into the development of such a machine. That is something to worry about when you're on the green, not just getting ready to tee off. It's a rather minor addition, not that major of a point on it's own.
Darwin will probably still be $100ish to build just for bars and misc parts. A design at $300, maybe even $200 all up, will still be a better option for many than you appear to be thinking it would be..
Actually, posting this has really got me off my behind. I've had people after me to get my CNC online for years and 4 GB of barely used web space, time to put it up. And you've helped me find it's true name!
It can't work!
It can't not even need CNC or wood working tools!
Do you know how many people on some of the lists told me you can't build a decent all metal CNC without special tools or woodworking equipment, when I said it could? Plenty. I knew it could be done before I even started, just from playing around with the rails before that. Took some time to play around with parts and arrangement, but it was a fairly trivial task.
Take a look at MOSFET based H-Bridge stepper controllers, especially ones that use all N-channel. Look at all those gate diodes and ask around why they're there. Uh, our gates blow, you need protection. Ask why do the gates blow? Try and find a real answer. They just threw parts at it, without bothering to really understand what the problem even was. Float the motor coils at +V with resistors and turn on the high side first and you don't need them with lover voltage motors.
