Proper way to unload filament? January 26, 2015 07:55PM |
Re: Proper way to unload filament? January 26, 2015 09:06PM |
Re: Proper way to unload filament? January 26, 2015 10:49PM |
Re: Proper way to unload filament? January 27, 2015 04:48AM |
Re: Proper way to unload filament? January 27, 2015 12:36PM |
Re: Proper way to unload filament? January 27, 2015 04:16PM |
Re: Proper way to unload filament? February 22, 2017 12:45PM |
Re: Proper way to unload filament? February 22, 2017 02:52PM |
Re: Proper way to unload filament? February 23, 2017 04:54AM |
Re: Proper way to unload filament? February 23, 2017 05:06AM |
Re: Proper way to unload filament? February 24, 2017 04:48AM |
DjDemonD
A lot of techniques here, I like to heat to a cool temp for the filament loaded say 180 pla or 210 abs push manually slightly then yank it out firmly, this ensures any slightly wider plug at the nozzle which is normal 1.75mm nozzles are 2mm bore, comes out cleanly. I believe this helps to pull old filament and debris out.
I then increase to normal printing temp and push the new filament through and then extrude 100mm or so to purge. Slightly more if swapping to/from pla as this jams much more easily than abs/petg.
