Some prints vulnerable to shifting February 01, 2015 06:54PM |
Re: Some prints vulnerable to shifting February 01, 2015 08:35PM |
Re: Some prints vulnerable to shifting February 03, 2015 10:00AM |
jbernardis
Shifting is either caused by mechanical issues, such as a belt that is too loose, or from dropped steps. Since your problem shifts between x and y when you rotate, I'll rule out mechanical.
So now we have the theory that it's from dropped steps. Dropped steps can come caused by 1) mechanical issues such as an axis that binds which is unlikely in this case, 2) improperly set stepper drivers which seems less likely since the problem shifts between axes, or 3) you're printing too fast for your printers mechanism. Acceleration and jerk settings are very important. If your carriage tries to change speeds too rapidly, it can drop steps. I notice this especially when doing infill in narrow spaces - about 1 or 2 mm. The head moving in short quick bursts can cause this issue if the speed is too high.
Re: Some prints vulnerable to shifting February 04, 2015 04:41PM |
Re: Some prints vulnerable to shifting February 04, 2015 08:59PM |
