Lack of torque in 1 out of my 5 motors
Posted by victorjung
February 04, 2015 11:57AM
Hi, guys, I just finished to built and wired my new 3d printer, it's exactly the same as my previous one which I am really happy with.
I have a lack of torque in one of the stepper, they are all the same 42byghw609 motors, they use all the same microstepping (1/16) But one of them has a poor torque despite whatever the potentiometer position is on the stepstick.
I am using ramps 1.4 with marlin inside.
When playing with the potentiometer i can go from no torque at all, to a light one.
Comparing to the other motors it's only the half...
I tried to change the stepstick... same problem...
All the jumpers are well placed ...
And the axis move the required distance at low speed.
But when I increase the print speed I have missing step...
It's hawfull I can't print quicker than 20mm/sec sad smiley
Any ideas from where it could be from?
Re: Lack of torque in 1 out of my 5 motors
February 04, 2015 12:23PM
Did you try switching motors instead of switching stepper drivers?
Maybe it's the motor and not the stepper driver.
Can it be that for that specific axis there is a typing error in the firmware steps/mm?
Did you try changing cables completely?
http://www.marinusdebeer.nl/
February 04, 2015 12:41PM
Hi thanks for the reply, as It 's newly wired and pretty nicely done, I dont really want to change wires, but the axis with troubles is X, so I plugged the motor X in the Y Slot and I got some torque, so it should be proper to the x part...
February 04, 2015 12:43PM
Well, then maybe you still have to take apart things, maybe there is a trace of solder shorting out something on the Ramps? If everything from the stepper driver to the stepper motor is ok, I can not think otherwise than that it's probably the Ramps that has a problem?
February 04, 2015 01:35PM
Ok finally it was, the stepstick, i managed to have more torque.
The thing is i thought it was skipping step but it wasn,t i accidentaly put a gt2 pulley with my t2.5 belt sad smiley this is why i was having troublessmiling smiley
February 04, 2015 02:00PM
victorjung
Oh no, that is terrible. I had the same problem with the first printer I ever bought. Bought a kit to be safe, but then it ended up being all mixed stuff... Good luck with the belts, and good you found out! smiling smiley
