Movement distance
Posted by Hellsbells72
Movement distance
February 25, 2015 09:21PM
I am designing a 3D printer using off the shelf linear actuator tables but I am still in the dark on how the g-code software knows how much to move the linear actuator. Anybody know?
Re: Movement distance
February 25, 2015 09:34PM
The G code only creates coordinates. It's in the firmware on your board that calculates how much movement equals the distance between coordinates.
February 25, 2015 09:35PM
KingRahl
So then the firmware has to be programmed based on the actuator used?
February 25, 2015 09:40PM
Yes. Using stepper motors we have to program how many steps it takes to reach a certain distance. That is the "calibrate" stage in building a printer.
February 26, 2015 02:36PM
When i built a new extruder for my 3d printer using a stepper and gear drive from a scanner, I simpley had to change the eeprom settings to a different steps/mm. It basically means "how many steps should I turn this motor to move 1mm?"
February 27, 2015 06:59AM
Hellsbells72
Conveniently, this setting is named "Steps per mm" :-)
Well, assuming you actually use stepper motors. RepRap firmwares generally don't really support servo motors.
