Hello all
After about a month of research and gathering materials (still need some..) I am in the process of eventually dirtying my hands.
First step is cutting the M8 threaded studding. Unfortunately it was sent simply wrapped so has some slight bend to it. Between 1mm and 3mm over the 1m lengths.
Is this a problem?
I anticipate it should not be too much of a problem as it is used for the frame. I intend to use the straightest bit for the lead screws...
Any advice or pitfalls I can expect?
Thanks
