Acetone Vapor Finishing Device March 04, 2015 04:22PM |
If You Can Read, Thank A Teacher. If You Can Read It In English, Thank A Veteran That's what you do in a herd: you look out for each other. - Manny from Ice Age |
New to 3D printing, not new to 3D or tinkering. LulzBot Taz 5 Generic Chinese 50w 300x500 Laser Cutter/Engraver (Ebay:171066211150) Corel X7, Photoshop CS6, Lightroom 4, Modo, Hexagon, Bryce, Poser |
Re: Acetone Vapor Finishing Device March 04, 2015 04:58PM |
Re: Acetone Vapor Finishing Device March 04, 2015 06:02PM |
the_digital_dentist
Acetone boils at about 56C.
That Peltier junction device is like any other semiconductor - you'll have to be very careful to ensure you can dissipate the heat it produces or you'll kill it very quickly.
Your idea seems overly complicated to me. Acetone isn't expensive or toxic enough to bother with vapor recovery. I think a real problem to be solved is circulating the vapor so it treats the entire surface of the printed part evenly. I think that could be done by using a motor outside the vapor container to rotate a metal fan blade inside the vapor container.
Re: Acetone Vapor Finishing Device March 04, 2015 09:28PM |
Re: Acetone Vapor Finishing Device March 04, 2015 10:31PM |
Re: Acetone Vapor Finishing Device March 05, 2015 08:48AM |
Re: Acetone Vapor Finishing Device March 05, 2015 09:32AM |
Re: Acetone Vapor Finishing Device March 05, 2015 10:54AM |
Dirty Steve
Hours for cold polish? It takes 40 minutes, if you leave it without checking on the progress, dries overnight. Unused metal paint can, completely lined with doubled up paper towels, held in place with magnets, soaked with acetone right to the limit the paper towels can hold. ABS part set on a sheet of glass, and the metal paint can inverted and placed over the part. DO NOT check the part in the 40 minute time span or you will loose the vapor when you lift the can.
I've polished a 12" tall piece with a 5 gallon paint thinner can. Now if you'd be willing to boil up acetone in a 5 gallon container, that's all you!
Re: Acetone Vapor Finishing Device March 05, 2015 11:24AM |
Re: Acetone Vapor Finishing Device March 05, 2015 12:39PM |
Re: Acetone Vapor Finishing Device March 05, 2015 02:31PM |
Re: Acetone Vapor Finishing Device March 05, 2015 04:10PM |
