I'm working on the "2 drive gears in one extruder" idea which hasnt gotten much attention lately. The issue Im having is due to the small diameter radius of the existing drive gears its really hard to find small enough cogwheels or pulleys and belts to drive two axis that are so close together. A bigger drive gear would take more force to move it would also increase the contact surface on the filament. So before I start working around this and make the system more complex I want to make sure that there isnt a drive gear with >20mm diameter out there.
Anyone ever seen something like this?
Cheers
