Dual Extruder Bowden vs. Direct Feed? March 20, 2015 11:18PM |
Re: Dual Extruder Bowden vs. Direct Feed? March 23, 2015 02:14AM |
Re: Dual Extruder Bowden vs. Direct Feed? March 23, 2015 05:59AM |
ggherbaz
For a Core XY you definitely need to go with bowden, if not you are killing the printer primary goal of speed.
Re: Dual Extruder Bowden vs. Direct Feed? April 05, 2015 12:31AM |
Re: Dual Extruder Bowden vs. Direct Feed? April 05, 2015 08:45AM |
Re: Dual Extruder Bowden vs. Direct Feed? April 05, 2015 09:26AM |
Re: Dual Extruder Bowden vs. Direct Feed? April 05, 2015 12:13PM |
Re: Dual Extruder Bowden vs. Direct Feed? April 05, 2015 12:53PM |
Zavashier
True, but the encoder management will be very exotic.
Re: Dual Extruder Bowden vs. Direct Feed? April 05, 2015 03:19PM |
Re: Dual Extruder Bowden vs. Direct Feed? April 06, 2015 02:27AM |
Re: Dual Extruder Bowden vs. Direct Feed? April 06, 2015 09:30AM |
Admin Registered: 15 years ago Posts: 7,864 |
Re: Dual Extruder Bowden vs. Direct Feed? April 08, 2015 08:46PM |
Re: Dual Extruder Bowden vs. Direct Feed? April 08, 2015 10:05PM |
Re: Dual Extruder Bowden vs. Direct Feed? April 09, 2015 04:32AM |
Re: Dual Extruder Bowden vs. Direct Feed? April 09, 2015 01:12PM |
No need for a servo, just use a stepper as normal.Quote
nophead
The way to go is probably a brush-less DC servo motor at the fixed end of the Bowden tube and a shaft encoder and pinch wheel at the entrance to the hot end with closed loop control.
