Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 25, 2015 02:07AM |
Re: Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 25, 2015 02:17PM |
Re: Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 25, 2015 02:41PM |
Re: Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 25, 2015 02:48PM |
The 24V boards basically take the 12V board and put a center tap on the trace. To run at 24V, you connect to the ends of the trace. To run at 12V, you connect + to the ends and - to the center pad (or vice versa). You could conceivably run 1/2 a 24v board by connecting just one end and the center pad, leaving the other end open.Quote
nope_bye
Interesting. So it can be done, but there would be issues with it? I didn't realize the beds with 12 or 24V were different circuits. I've never used one.
I think the difficult part would be to get the traces such that only the central area is energized while the exterior areas aren't while keeping it a single sided PCB. And balancing the traces so that they have the same resistance unless you don't mind unbalanced circuits.Quote
Why couldn't the smaller area be in the center?
Yup. The heat spreader is designed to....spread the heat. If you don't have some type of thermal break, as it heats up heat will be wicked away from where you want it to where you don't necessarily want it.Quote
And why would separate heat spreaders be necessary? Is it because a larger one would warp or carry away too much of the heat?
Re: Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 26, 2015 07:38AM |
Re: Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 26, 2015 12:43PM |
and doing a lot of sucking numbers out of the end of my thumb. My 200mm X 200mm bed takes say 100W for a temperature of 110 degrees C. For your 300mm X 300mm bed this would be about 225W with the 150mm X 150mm bed taking about 68W, saving 157W. If i take a wild guess at your electricity costs at 20 US cents per kWh then on a 10 hour print would save you about 1.57kWh or about 31 cents.Quote
I was just wondering if it's possible or even worth it to make a heat bed with dual circuits.
Re: Has anyone ever made a pcb heat bed with two circuits? Is it a dumb idea? March 26, 2015 05:01PM |
leadinglights
Nope, I don't think that it is worth it.
Mike
