0 volts to hot bed and hot end from ramps 1.4 -=SOLVED=- April 19, 2015 01:50PM |
Re: 0 volts to hot bed from ramps 1.4 with marlin firmware April 19, 2015 03:21PM |
Re: 0 volts to hot bed from ramps 1.4 with marlin firmware April 19, 2015 04:15PM |
Re: 0 volts to hot bed from ramps 1.4 with marlin firmware April 19, 2015 06:37PM |
Re: 0 volts to hot bed from ramps 1.4 with marlin firmware April 19, 2015 09:13PM |
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 19, 2015 09:21PM |
Re: 0 volts to hot bed from ramps 1.4 with marlin firmware April 20, 2015 07:52AM |
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 08:33AM |
Re: 0 volts to hot bed from ramps 1.4 with marlin firmware April 20, 2015 10:05AM |
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 10:12AM |
cdru
What's the voltage from the + terminal from either the hot end or heated bed to the - terminal of the main power connectors?
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 11:17AM |
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 01:18PM |
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 01:30PM |
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 02:27PM |
RAMPS switches the negative leg. I'd measure for continuity from the - D10 connector to the drain pin, the source pin to the power - connector, and the D10 pin from the Arduino to the gate pin. Make sure all those are good.Quote
lunarkingdom
This man deserves a medal, the positive sides of both the hotend and hotbed are working, it is the negative side that does not. Anyone know what to look for on the ramps board if the negative is not working on this connector?
Re: 0 volts to hot bed and hot end from ramps 1.4 with marlin firmware April 20, 2015 06:09PM |
Re: 0 volts to hot bed and hot end from ramps 1.4 -=SOLVED=- April 20, 2015 10:35PM |
Re: 0 volts to hot bed and hot end from ramps 1.4 -=SOLVED=- April 20, 2015 10:36PM |
